(Failed to load because of a critical system driver is missing, or corrupt)
gordie
File: \windows\system32\drivers\ltoxvyo.sys
status: 0xc0000225
Vista Home Premium.
need some help on how i can get this machine functional again.
i do have the vista installation disc unfortunately due to the short length of the SATA connectors from the power supply they simply do not reach the ROM drive while being connected to the hard drive at the same time.
if anyone needs any more info just ask.
help would be much appreciated,
americancritic
Hello and welcome to the forum...
Can you tell me if you can get to your main desktop if not have you tried to boot in safe mode. Here's how to boot in safe mode just in case.
http://www.vistax64.com/tutorials/123496-safe-mode.html
But please let me know if you can get to your desktop.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
richc46
That driver may very well be a name changing Trojan. My conclusion is based upon the fact that using Google and several other search engines, no topics are shown. May I suggest that you do not attemp any other solutions until our Security expert takes a look. At this stage, you can safely do a format with a reinstall, but I will have her come and give her opinion.
Jacee
Security
Hi gordie,
That file is malware. Download Malwarebytes' Anti-Malware to your desktop
|MG| Malwarebytes Anti-Malware 1.50.1 Download
* Double-click mbam-setup.exe and follow the prompts to install the program.
* At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
* If an update is found, it will download and install the latest version.
* Once the program has loaded, select Perform full scan, then click Scan.
* When the scan is complete, click OK, then Show Results to view the results.
* Be sure that everything is checked, and click Remove Selected.
* When completed, a log will open in Notepad. Please save it to a convenient location. Copy and Paste that log into your next reply.
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device.
    One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
