Family Tree Maker 2014 - Lost CD
petbro
I installed FTM 2014 via CD that was later stolen from my home address. However i had a back up copy of the programme files on an external hd and was wondering if there is any software out there that would help me make a install CD using the original files?
    Toshiba Satellite L300D-13S
    AMD Turion(tm) X2 Dual-Core Mobile RM-70 2.00 GHz
townsbg
~~тσωηsвg~~
If you are referring to using the files created by the installer you can't use those to create an install cd and you can't likely use them to install on another computer. I suggest that you contact the publisher and see if they will send you a new one.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
petbro
Hi, townsbg, sorry for the delay in replying. That's exactly what i wanted to do. Since posting i have found my FTM 2011 so i'll just have to go back using that with original tree files. I did have a look at PowerISO but that can only make a boot drive through ISO.
You live and learn. Thanks
townsbg
~~тσωηsвg~~
You run the program through the files on windows however you must use a special installer to get them on there. That installer is on the cd. The files just don't transfer like that. Installing a program on windows involves creating registry entries as well as configuration files and the program files on your hard drive don't do that. Only the installer does that. I hope that helps.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    Poweredge T140
    1440 x 900
    1 TB & 360 GB
