Fan speed control
Techymike
not so newbie
Power User
Has anyone else noticed that the GPU fan speed control is not functioning with Vista 64 and the Radeon 3870x2? I am running Riva tuner to make the fan operate manually but I once had the option with Vista 64 and not flashing the card either.
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
sygnus21
Here to learn
Tried using the fan control option in the Catalyst Control Center?
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Techymike
not so newbie
Power User
I would if it was there. I have read there is some sort of a problem with that function when running the 3870x2 card. The card is supposed to be flashed so that it can work but I do not wish risking harming the card by flashing so I use rivaturner.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
Techymike
not so newbie
Power User
Here is the way CCT works with the 3870X2 card
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
sygnus21
Here to learn
Yeah, I did some research and see the 3870x2 doesn't have the fan control option. Don't know what else to say; I've never used Riva Tuner so I have no suggestions there either. I don't even use the CCC's fan control with my 4850, which incidentally, replaced my 3870.
No other suggestions here.
Good luck.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Pokerking
Hey
I installed SmartDoctor with came with my 4870.
It has fan speed control.. My 4870's CCC doesnt have
fan speed control either..
Hope this helps
Pokerking
Hey
Hope this helps
Airbot
I have no fan control option either. :(
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
archie123
I Tunes hates Me
Riva Tuner is a lighweight app , ive been using it for years for custom fan profiles , stick with it mate , its less hassle ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
sygnus21
Here to learn
Hey
Hope this helps
You need to have an ATI 4800 series card to have the fan control option under Catalyst Control Center. I have a VisionTek 4850 and it has the fan control option under the Catalyst Control Center (9.2); has been there since the 8.10.
New Catalyst 8.10 Drivers Bring Fan Speed Control - Tom's Hardware
Catalyst Control Center™ Fan speed control
Also, in order to access the fan control option, you'll need to "Unlock" Auto Tune.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Airbot
Ahh, that I don't have.
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
Techymike
not so newbie
Power User
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
moirae
Pew Pew lazor beemz
Rivatuner is a godsend.
I have a GTX280 and they just run so freakin hot.
Over the summer here, it was like having a fan heater on the side of my desk.
Changing cases to something with much more airflow, plus using Rivatuner allows my card to run under full load at under 55 degrees. Mind you, the fan is as loud as hell, but I'm happy if that card is kept cool.
The gigabyte card came out of the box with the idle fan speed @ 40%..Under load it would increase to 60% and if it got hotter still, it would only go to 80%.
Some of the Thermalright after market coolers look pretty sweet just quietly...
    My build
    Core2Quad Q9550 yorkfield C1 3.8G
    GIGABYTE GA-EP45-UD3R
    8gig Kingston HyperX 8500 CL5
    Gigabyte GTX280 1G...generally stock.
    onboard
    Samsung 24" 2433bw + Benq 19" FP91G+
    2 x Samsung 500G Raid0
    1 x Samsung 1TB 32
    Thermaltake Toughpower 850W
    Antec twelve hundred.
    Air...a lot of air. Thermalright 120 push/pull,8 case fans,
    Logitech G5
    Logitech G15
    ADSL2
