Faulty drive - can I run some sort of diagnostics?
Dinarius
Vista x 64bit
I have three internal drives, C:, D and E.
D and E are used for storing digital image files.
Just now I got an error message saying that the E drive was reporting a problem and I should back up the computer. Since the E drive is backed up daily to an external drive, I ignored this.
Both D and E are 2Tb drives that I had recently installed, so I am a bit surprised at this problem so soon.
Is there any inbuilt diagnostic and repair tool that I could run to check for and repair errors on the E drive ( and the others while I'm at it)?
Thanks.
D.
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
Dinarius
Thanks.
I ran the inbuilt diagnostic tool, ticking both boxes (sytems errors and bad sectors) and this took all night!
When I checked this morning, it said that the disk was now OK and ready to use.
It also said that problem files had been placed in a new folder called "Found".
I cannot see this folder anywhere.
Any idea where it might be or how I might look for it?
Thanks.
D.
Shadowjk
Network Enthusiast
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
Dinarius
May I suggest running a Checkdisk
See http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html For More Information
And please Tick both Boxes
This May take some time
That's what I did run and it took all night.
The drive had been making an odd noise (at least I assume it was this drive - I've got three internal drives) and the noise has now stopped.
It's the Found folder that was created by Check Disk that I'd like to locate. I'd like to see the files it put there.
Thanks.
D.
