Fifa 10 problem
Prak06
Hey all, i recently bought FIFA 10 and installed it today... i launched the game with no problem BUT its only when i got to the menu i encountered this problem were i can not select the option in the menu because it keeps scrolling through all the options... as if i am holding down the down arrow key on the keyboard.
Does anyone have any suggestion why this is happening... i have never encountered this problem before in any other game, it only happens to be FIFA 9 and 10?
Thank You.. look forward to you replies
    Dell Vostro 410
    Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz (4 CPUs), ~2.7
    NVIDIA GeForce 8800 GT
    Creative X-Fi Xtreme Music
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
For those that do not understand what i am trying to say in the above message, i uploaded a video to show you the problem...as i don't know how to put it in many words:
YouTube - FIFA 10 PROBLEM
    Dell Vostro 410
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
You did a great job of illustrating your problem. What if you play the game in XP compatibility mode?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
Unfortunately, that did not work.. i gave running in administrator mode a try..but also failed.
Any other suggestion Lemur?
    Dell Vostro 410
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
This has to be the demo version, right? Do you know of anyone else running it in Vista?
Just for the heck of it, make sure your mobo bios, video, and all other drivers are the latest greatest.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
No it the Full Fifa 10 Version.
Checked all drives.. all up to date...
Still encounter the same problem?
    Dell Vostro 410
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
Hello Prak06,
Sounds almost like a sticky key problem, but why just in that game, and on that menu, can you just check to see if any of the sticky key features are turned on.
You will need to look in the "Control Panel\Ease of Access Centre"
Take a look and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Hi stoneys-nutz
I think the problem lies in the controller (PS2 Gamepad), that i have, when i disconnect it i find that the "Scrolling action" doesn't happen.
The "Scrolling action" (If you don't understand what i mean by that check the you tube video out in the above post :party:) happens throughout the game, where ever there is an option it will keep going down... not only on the menu page. :sa:
Here is a screeny of my sticky keys option
    Dell Vostro 410
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
I would uncheck them all, just to see what happens, but i suspect it's the controller , although you would think that it would do it in all games.
When the game is running unplug and reconnect the controller, that will sometimes reset the controller.
Also go in to the controller options/setup and see if it is behaving normally there.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
when i start fifa 10 and play a match the screen turns blue and no natural graphics is seen but i am having all minimum requirement
