You should upgrade or use an
alternative browser .
Solved File does not have a program associated with it
I am unable to open any file with the .pps extension. I keep getting this message:
"This file does not have a program associated with it for performing this action. Create an association in the Set Associations control panel"
I'm sure this has probably been answered before but this is my first time on this forum and I didn't find it under FAQ.
I'm not a computer person so an answer in plain language would be greatly appreciated. Thank you.
OS: Windows Vista Home Premium 32bit
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
I downloaded what you suggested and am still getting the same message.
Operating System
Operating System
Uninstalled first suggestion and then installed the 2nd suggestion. Same message.
I do not use Power Point for business so for me to purchase the program would be a waste of $. I was just trying to open a couple of attachments to emails.
Thanks
Try saving the attachment to your desktop, then see if it will open it with the newer PowerPoint Viewer program.
Operating System
Operating System
That worked. The email attachment wasn't worth it, but I was able to open it.
Thank you.
You're most welcome. Maybe the next one will be.
Operating System
Operating System
