My computer has been running nicely on the Windows Vista OS for the last few months. Today I tried to add a new user and then I began getting some peculiar problems so I deleted that new user. Then I tried to open Windows Explorer but it failed. I saw that explorer.exe was missing from my System32 folder so I copied explorer.exe from my Windows 10 computer to the Vista computer .Then I tried to load explorer.exe (Windows Explorer) and it failed with an Application Error. The app error read "...failed to initialize properly (0xc0000142). Click OK...". That was followed by a message saying, "Windows Explorer has stopped working."
So I clicked OK and opened my alternate file manager Explorer++.exe. It opened correctly. However, when I clicked on Start>Settings>Control Panel>Welcome Center an error message came up that said "Application not found".
I clicked OK and then got the same results when I clicked on the Backup and Restore Center, the System, the Windows Update, the Power Options, the Problem Reports and Solutions, the Performance Information and Tools, the Windows Anytime Upgrade, and the Administrative tools. Other things in the Control Panel seemed to come up okay.
And I got the same results for Control Panel>Programs>Programs and Features, Default Programs, and Windows SideShow.
So then I tried to uninstall Explorer++ but I couldn't because I couldn't get into the Programs and Features part of the control panel using either Explorer++ or Windows Explorer.
I tried restoring using the options in Bios power-up boot menu and was not successful. I didn't try restoring back to the original operation system because the last time I did that it took several long, long hours. So I thought I'd ask here if there is something else I can try before I reinstall Windows Vista from the original diskettes.
- Operating System
- Windows Vista SP2
- HP a6400f
- 3GB
- HP 19-Inch
- 500GB
- Not connected
