Can anyone tell me if I can change the templates used to display folders in Vista.
I've searched the forums and discovered plenty of tutorials about the problem of Vista remembering the template used and how to change which template is used.
But that is not what I want. I actually want to change the template itself (In an ideal world I'd like to create new templates), but at the minimum I'd like to change what the existing templates show.
For example, I have a number of Sound FX files and for those, I'd like the template to show the length of the clip. Similarly, I do not use Ratings, and have no use for them or Genres or track numbers, but I would like file size. For Images, I again never use Ratings, or tags (I use Adobe Lightroom to catalog my images as I have thousands) but I would like to see file type and modification date!
If this has been answered I apologise, but I did search first and couldn't find an appropriate answer.
Thanks
Thanks
- Home made
- ASUS
- 4Gb
- Graphics Card(s)
- GeForce 6600
- Soundblaster Audigy SE
- Samsung & Dell
- 1920 x 1080 & 1280 x 1040
- Seagate, Maxtor & Samsung
- PSU
- Enermax 500
- Case
- Antc
- MS
- MS
