Folders, View, Preview Pane
Crabcakes
I apologize if this is a duplicate question- I have searched this forum and not found this topic.
In WinXP, when selecting View Folders, I would see a closed folder, with 4 small images of the folder contents. I liked this as I instantly knew what images were in my folder. I am drilling down as follows: Documents, then the folders come into view. These are the folders I am discussing here. Windows Explorer gives the same results.
In Vista, I get a partially open folder, with the contents partially visible, but cascaded so as to obscure the contents under the first view. I've tried all the possible options I can find withing Vista, including Large Icons, etc. I have searched online for how to make the folders give me the preview pane as in XP, to no avail. I have tried numerous fixes found online, but they do not work. I may be using the wrong terminology, but I have spent two months trying to get the folders to display as in XP. Would someone here know a fix for this?
Thank you in advance! Great forum here, BTW!:)
dmex
ɠɛɐǨ
Hi Crabcakes,
Try going to (top left) Organise> Layout> Preview Plane in the folder you would like to see image previews ;)
Let me know if thats what you where looking for :geek:
Steven
Crabcakes
Thanks for your quick reply, Steven. I have already tried that, but it is a good try. I probably did not explain real clearly!
In XP, it gave me a CLOSED folder preview, with four small images on the outside cover of the closed folder. Now, in Vista, it is a partially open folder, with the contents cascaded.
I would LOVE to have it preview as in XP. I wish I could send a screen shot, and may later if I get access to an XP machine.
Thanks so much!:)
Spd2Last
Pre-Engineer
Vista Pro
I've posted up a screenshot of what Crabcakes was talking about.
Unfortunately, I don't think there's a way to get that same folder preview in Vista.
Someone correct me if I'm wrong...
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II
    500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
Spd2Last
Pre-Engineer
Vista Pro
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    Asus Xonar DX
    500GB WD SATA II
    Logitech G5
    ~3Mb
