Format my computer due to viruses
7
I cannot install windows 7. During the installation, a compatibility report goes on my desktop and it says it cannot open the web page, that I have to retype the address. After, the installation stops...
I have vista, and dowloaded a windows comptability advisor, but doesn't work either. Did anybody have that problem?
Judy
    Asp
richc46
Staff member
20,105
Location
Fairfield County, CT
richc46
Staff member
20,105
Location
You are very welocome, Judy
If you have any other questions, just post
richc46
Staff member
20,105
Location
How are you going to reinstall?
If you plan on using the restoration partition, that will format for you.
townsbg
~~тσωηsвg~~
2,248
Location
US of A
If this is a manufactured system the manufacturer might have built in the installation files into the hard drive. Look in your computer's documentation on how to access it.
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
7
#8
I found it and I used it several times to reformat my computer, but, since, my virus, it wont let me... I tried to delete the virus, but i guess it is still there...
If i dont have a cd and the program i had on my computer was reformat my computer, but not anymore, what should i do now?
    Asp
richc46
Staff member
20,105
Location
#9
If the partiton no longer works, you must call the computer comapnay and get an install DVD for cost $25.00. If they are no longer available, you may borrow one, but you would need the key number that is located on the computer.
or
I would buy an upgrade version of Seven, if your computer can handle it.
7
#10
I tried to install windows 7, but again it said it couln'd open the web page during the installation... and my internet was on...
comptability report goes on my desktop and then it doesnt want to open, it says the page was cancelled, typed the address again
    Asp
richc46
Staff member
20,105
Location
#11
7
#12
Problem with windows 7 installation
I got a virus and since then, my computer doesn't work well, even after i deleted it, or maybe it is still there...
I'm trying to install windows 7, but during the installation, there is a comptability report that goes on my desktop and it says that the page couldn't open and i have to type the address again... And the installation doesn't work...
I have a windows vista, and i dowload a windows comptability advisor, but it doesnt work either, it says wait for a few minutes, but it never stops scanning...
Did anybody have that problem and how did you over pass the problem?
    Asp
112
#13
control panel->system and security->bottom of list create and format partions
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    hp 27 inch 1080p and gateway 23 inch 1080p
    western digital 1tb
    stock 250watt
    stock
    stock
    logitech k320 wireless
    comcast cable 20meg
