G:\ is not accessible Incorrect function
Jerin
Power User
113
Another Issue -
Iomega External DVD+-RW
The problem is that i can play CDs and DVDs using this drive but when i put a blank CD or DVD and try to open it - it gives an error G:\ is not accessible Incorrect function tried to delete the upper/lower filter still not able to open a blank media.
Anyone with the same issue - what can be done --
Waiting
JERIN
Tepid
Power User
66
Try installing a trial version of Nero, but only install the BurningROM portion, not all the other bloated junk. BurningROM is still one of the best out there.
Or try DeepBurner Free and see if this helps.
DeepBurner won't let you format and use the disk as drive (that I know of) but it may allow you to burn a folder and files etc. to it. Same with BurningROM.
I personally have never liked Windows Builtin Burning Feature, never had that much success with it.
Other than that,,,,,,, may be a problem with the drive itself. Or check the properties of the drive and make sure it is set to allow burning.
There is also a Group Policy that will disable burning functions.
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
Try updating or installing drivers for the DVD drive.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
