You should upgrade or use an
alternative browser .
Gears of War Problem...??? :(
Hi all, whenever if run the game through "startup":huh: a prompt comes up saying "You cannot run the game with modified executable code ...Re-install the game"
I installed the game again but it behaves the same:sa:... how can i run the game...
OS used: Vista 32 bit.
AMD Phenom 9850 Black Edition
ASUS M3N78VM
NVidia 8800 GT 512 MB
22"
1600X1200
500 GB Seagate
That is an error that you get for having installed cracked software.
HP Compaq Presario/SR5113WM
AMD Athlon 64 X2 3600+ 1.9Ghz
Asus M2N68-LA
PNY Nvidia 8400 GS 256MB
On board RealTek
Acer X163W LCD
1366x768
7200 rpm
Western Digital 160 GB IDE
Dynex 400w
Nothin Special
Stock
Wireless Logitech LX7
Comcrap 10mb cable
After some gooling i found it to be related with system date settings
... now its working.....:D
ASUS M3N78VM
22"
1600X1200
500 GB Seagate
download the patch for the game and it will work
Gamerholic
Hello Looser007,
The problem is caused by an "expired digital signatures issue".
You need to download the latest patch from here.
http://gearsofwar.xbox.com/pc/qfe1.htm
I had the same problem, and i don't use cracked software.
The patch will sort it.
Self Build
QX9650 (black box) [email protected]
Asus P5Q Premium
2 x ASUS EAH 4870 X 2 (Quad)
Supreme FX 2
150 Gig WD Raptor
300 Gig Maxtor
300 Gig Maxtor, (External)
CoolerMaster 1000
Logitech G15
Logitech G5
20Mbps
