Geforce 7600 GT
65
Location
Oklahoma City
When i start my computer my graphics card starts out like hot but not really hot when i start playing games is it because my fan has a lot of dirt in it and its heating up my computer or do i need a water cooler that bad?
206
clean out your system. also you might want to get some more fans in your system.
Yes most graphics cards run bloody hot especially when running games
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array
    3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
65
Location
Oklahoma City
I dont think i can fit another fan inside it only fits one or i can upgrade to a better fan to bigger size but i dont think it will fit ethier because the stock one i got right now is pretty much sitting on the ground heres a pic
Heres a pic of the whole inside as u can see i cant fit any more fans :(
206
you can always fit more fans. buy a fan, mark it on the side of your case where the screws will go and the outline of the fan, and cut through the case with a diamond saw or something, DIY or you could buy a new case (or even better buy a new pc - i guarantee you can buy one better than that for $300 - that's how much it cost to set up my mailserver for work)
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
206
you also still have so many outputs from your psu, enough for many fans. just wack em inbetween your graphics card and the other PCI expansion card
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
206
#9
you dont have to plug it into the motherboard, get one that will plug into the PSU, and if you paid $995 for that within the last year, you were ripped off by alot of money.
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
avgwarhawk
Power User
196
#12
I got in 2007-2008 like the start of 2008 but o well it was a birthday gift
what is the psu?
PSU is power supply. The big square power unit inside the computer. This has a fan also. Do you have an exhaust fan out the back of the computer case. Also, why are you worried about heat on the video card? Cards to run hot especially when gaming. If the card is within the specs for heat no need to worry.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
avgwarhawk
Power User
196
#13
To the right of this fan in the case...there is another place for a fan. You can put a fan input here power it right off the PSU. Fans can be had for about 10 bucks.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    650 watts
206
#14
what is the psu?
So you paid 1K for that, and now its a gift. The plot thickens
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
206
#15
You can connect more fans to these outputs from the PSU, but I dont think you need more fans unless you are overclocking. just clean out your case. handheld air compressor $2. Peace of mind priceless. zoom into the image and then see the red boxes
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
