Good graphics card for Vista PC?
Good morning everyone,
I was not sure where to ask so I thought I should post here in my favorite forum. I have just built a new desktop PC with the following configuration:
Mobo: Gigabyte 78LMT-S2
CPU: AMD Fx-4300 3.8GHz
RAM: 4GB DDR3 800MHz
HDD: Seagate ST3320820AS
Video: On board ATI Radeon HD 3000 (AMD 760G chipset)
The PC is okay for everyday use but I want to improve the graphics. More specifically, I would like to have HDMI (The Mobo has only a VGA port) and be able to play games like StarCraft or Crysis 2. On the other hand, I cannot afford buying the most expensive graphics card out there.
So, what graphics card do you suggest I should buy that fits my hardware configuration and requirements?
Thank you in advance,
    Dell Inspiron 1525
wither 3
You said you wanted HDMI. Does your monitor have a HDMI connector?
How much are you willing to pay for a new card?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
One very important consideration is your power supply. How powerful is it?
When Crysis came out it required was was at that time a very high end graphics card. When dealing with very resource intensive games you don't want to cheapen out or you will end up with poor performance or have to play the game at a lower frame rate. The same is true of your PSU. If you upgrade your graphics card more than likely you will have to upgrade your PSU so factor that in to your budget. Unfortunately you may not want to pay for the most powerful but games such as Crysis require the most powerful.
Yes, my monitor has HDMI and my PSU is brand new and very powerful. I know nothing about the cards of the ATI Radeon family and I am looking for suggestion. I can afford paying up to $120.
    Dell Inspiron 1525
wither 3
Recommending a specific card is a can of worms. If we recommend a card, you buy it and then aren't happy, you'll be plenty mad at us. I'll stick my neck out and say take a look at the EVGA gtx 750. It is available in your price range and not only supports HDMI but, also, Displayport 1.2. You should compare it's specs to those required by the game you want to play.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Patonb
You need to check your power supply. Most cards that will do what you want need 400+ W psu.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
wither 3
For information, the GTX 750 requires a minimum 300 W PSU.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Tk Desimon
GTX 750Ti is a little more exensive but gives you a little more performance...if you have a brand new CHINESE PSU... first change it with a serious brand new PSU (must be a 500+W PSU)...then purchase GPU...
Otherwise you will cook your PSU and HW components.
:D
    Custom Made
    P4 Extreme Edition 3.73 GHz @ 4.00 GHz
    ASRock ConRoe 1333 D667 R2.0
    2x Kingston DDRII 800 2GB
    NVIDIA GeForce GTX 750Ti 2048 PCI-E
    Integrated
    32" LG TV
    WD Black 2 1TB + 120GB 2.5"
    2x SEAGATE 1TB SATA 3.5"
    2x MAXTOR 80GB ATA 3.5"
    2x TOSHIBA 500GB SATA 2.5"
    Atlantis 600W
    Hyper T4 CoolerMaster
