Got the dual network issue...
Pott
1
Hey guys, I'm new here, found out the forums after a quick google search on this issue...
You know, where the wireless somehow splits your home network into two parts and can't get to the Internet...
I tried the route delete 0.0.0.0, and the deleting of the ipv6. There were no Wake On Lan options so I couldn't disconnect that. But all this to no avail, still there.
I disabled the drive and enabled it again, it's working now but I hear only until next restart?
Did I do something wrong with my solutions? I disabled ipv6 both on LAN and wireless. Do I need to enable, or disable LAN, if I'm using wireless?
Thanks, I hope y'all can help, I'm stumped on this :( Sorry to bother you with that thing again..
johngalt
Antidisestablishmentarian
3,913
Location
3rd Rock
Hi, Pott, and welcome to the forums.
First of all, if you found the forums from a Google search, and the post was related to your problem, then posting in that post would have been the route to go. If it was not related but you found us anyway, then my apologies and good job on making a new post for your issue.
Now, since you have it working right now and you know of potential problems, I'd test it by rebooting and seeing if it changes or not. Also, have you changed your router's default login PW? Finally, Enabling / Disabling LAN should have no bearing as that refers to wired connections and cannot be 'hacked' without someone attaching a cable to your router. Of course, if you *do* have wired connections, then disabling LAN will disable all of those computers' connections, so obviously you don't want to in that case.
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
