Solved Graphic Card Question
VFN
I have a Radeon card which uses CCC: Catalyst Control Center (Not even sure if that makes sense as I have no understanding of drivers or cards.) I was thinking about updating my CCC and the AMD tutorial video recommends uninstalling the CCC first, restarting, then installing the new CCC version. If I can remove the CCC and restart what exactly does it do, why can I see graphics without it? Does a Windows general graphics utility or something take over?
Thanks,
VFN
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
Patonb
CCC is the official drivers and options program needed to get the most out of the card. That said, MS has generic drivers that gives basic functions so you can see as you install windows and do clean installs of drivers. Same reason why you can see the BIOS screens.
So don't worry, you'll be able to see, just might be at huge resolutions, when you remove CCC.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
    Country Flag
    canada
VFN
Thanks for the reply.
What about the driver I see in my Display Adaptor/Graphic Card in Device Manager? Is that part of CCC or separate. And if I were to uninstall that would Windows reinstall it after a restart?
Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Patonb
You need to reboot, and that's when it officially uninstalls. The reboot loads the generic windows driver till you install the AMD ones.
    Country Flag
    canada
VFN
Thanks. You've helped me understand things better.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
