Halo 2 vista help
DirtRid3r
I installed Halo 2 and when I click to play the game, I get an error that says: Initialization failed. Either insuffecient resources were found to run the game, or game data is missing or damaged. Reinstalling the game may fix this problem.
Now I tried reinstalling the game and this error still comes up.
DirtRid3r, please post ur PC specifications or better still, edit your signature to include your specifications. That way, u wont have to type it out everywhere, every time.
Coming to your problem, Either you have insufficient RAM, or Insufficient free space on the drive where u installed the game or the drive where windows is installed. Other possibility is that, u might be short on free RAM. Try closing down all running applications like chat programs, n anything else unnecessary [but don't ever do away with your antivirus or your firewall]. If that dosent solve it in terms of freeing resources, u might wanna disable Aero and give it a try. U can also do a quick reboot to free up resources [this dosen't include Disk drive space].
Hope this helps!
    Custom Built Gigabyte-Intel-ATI-Transcend-SONY combo
    Intel Core2 Duo E6300 1.86GHz
    Gigabyte G31M-ES2C [Intel G31]
    1.5 GB DDRII 667 MHz [512+1024]
    Sapphire ATI Radeon HD 4770 512 MB GDDR5
    Realtek HD Audio [ALC882 codec onboard]
    Samsung SyncMaster 2033SW+ (20" Wide)
    1600 x 900 x 60Hz @ 32bpp
    1 x 40 GB P-ATA
    1 x 160 GB S-ATA [Win7 with Win XP SP3 dual boot]
    1 x 1 TB S-ATA
    VIP 400 W
    Zebronics Elegance
    All fan [2 on case side and 1 behind]
    i-ball i-key Multimedia keyboard
    Logitech Standard Optical Tilt-Wheel Mouse
    256 kbps Cable
Your spces. are incomplete, you atleast have to mention your graphics card. no point in playing Halo 2 if you dont have a compatable graphics card
    1 x 40 GB P-ATA
    1 x 1 TB S-ATA
    VIP 400 W
    Zebronics Elegance
    256 kbps Cable
i have the same problem i have 1gb mem 256 intel 946 chipset family dural 3ghz processor and i get that same error can i get help?
Hi Mackess,
Your intel 946 chipset is the problem. Get a proper Graphics card to run the game not an internal graphics chip.
Steven
Same issue as above, if your graphics adapter starts with "Intel..." you need to get a new one if you wish to game.
Using Intel graphics is like trying to run a car on a motorized toothbrush.
    T8100 (2.10GHz Penryn)
    HP HDX Notebook
    4GB DDR2-667 CAS4
    nVidia 8800M GTS
    Travelstar 7K320
    Travelstar 5K320
I have the same problem too... my graphics card is Intel R 945 Express Chip Family and i have 1014 Ram with 17GB hard drive left
Hey Guys,
Socket is correct, The Intel 945 Express Chip is not designed for Gaming let alone the Areo theme on Vista, You will need to upgrade it ;)
Steven
I have Halo 2 and a Saitek p3600 rumble control pad. Everything works except this.
The config buttons work except the triggers. Every time I press them the game turns sideways in adition to shooting. How can I keep the game from turning when I press the triggers? Any help is deeply appreciated.
    Alienware, Area 51.
    Pentium Quatro.
    Sly.
    500 GB.
    Nvidia GeForce 9800 GT.
    Creative Labs SB X-FI Fata1ty Pro Gamer.
    Samsung FP-T5084.
    1080P.
    Western Digital My Book. External Hard Drive.
    Alienware, Gray.
    Saitek P2600 Rumble Control Pad. (Doubles as a mouse.)
    Broadband, Cable.
    Computer Knowledge. Medium.
Hi graysky, welcome, can I ask you to download these drivers for your pad and see if that fixes the issue > ftp://ftp.saitek.com/pub/software/full/Saitek_Range_Pad_SD6_00000038_32_Drivers_pfw.exe if it doesn't fix it then we can have a look into more options for you :-)
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
It didn't work. I can remap the buttons but the control is faulty.
    Alienware, Area 51.
    Pentium Quatro.
    Sly.
    500 GB.
    Samsung FP-T5084.
    1080P.
    Alienware, Gray.
    Broadband, Cable.
Can you take a screenshot of what happens when you press your triggers, I'm not entirely sure what you mean when you say it turns the screen, do you mean it's like moving the analog stick to change direction or is it rotating the screen itself?
MrNeeds
    16Mb Sky bb
It's like when I press one of the triggers the screen turns like if i was looking, or scrolling sideways with the mouse. the right trigger moves the mouse, or screen, to the left, and the left trigger moves the screen to the right. + When I have dual guns I can't move to the right using the left analog knob. Please help.
    Alienware, Area 51.
    Pentium Quatro.
    Sly.
    500 GB.
    Samsung FP-T5084.
    1080P.
    Alienware, Gray.
    Broadband, Cable.
Have you calibrated the controller in the control panel within windows? The reason it does this is because the triggers are not buttons but separate axes' but for it to interfere with mouse movements is very strange, I'd be looking at control panel controller configurations to try and fix this issue.
MrNeeds
    16Mb Sky bb
Thanks! I gave my sister my Saitek p3600 rumble pad today, because her Saitek p2600 was really giving her problems with her pc. I no longer have my control pad to test, but if there's a solution, I definitely want to know. I can use this info until I buy a pad for me.
~Art~
    Alienware, Area 51.
    Pentium Quatro.
    Sly.
    500 GB.
    Samsung FP-T5084.
    1080P.
    Alienware, Gray.
    Broadband, Cable.
~Art~
Hey graysky, sorry to hear you got rid of your pad, I have to say, for your next pad, you may want to go down the Microsoft route, the xbox 360 controller is fully compatible with all "games for windows" games, no mapping needed, and it will work for halo 2 straight out of the box, it maybe something to look into :-)
MrNeeds
    16Mb Sky bb
Thanks. I'll do that.
~Art~ :)
    Alienware, Area 51.
    Pentium Quatro.
    Sly.
    500 GB.
    Samsung FP-T5084.
    1080P.
    Alienware, Gray.
    Broadband, Cable.
I purchased a brand new copy of Halo 2 Vista and it installed perfectly and runs perfectly except for the Product Key doesn't work. I would contact the seller, but there's nothing they can do. They sold me a factory sealed brand new copy of the game. I tried talking with Microsoft support and they sent me here. I'm not going to dare trying an illegal Key generator, that's why I made sure I purchased a brand new copy of Halo 2 Vista.
