Solved Hard disk volume question
damocles
virtue & horse hair
Vista Pro
In my Event properties I getting a NTFS error that the file system structure is corrupt and unusable.
It tells me this is volume\Device\ HarddiskVolume3
Question is, Which hard drive is that?
In disk manager I have the following
Disk 0 F: drive
Disk 1 D: drive
Disk 2 C: drive
Disk 3 H&P: drive
Disk 4 G: drive
Disk 5 M: drive
I guess that's kinda messed up..huh!:confused:
plus other removable cf card / sd card / mmc card drives
I need to Chkdsk the volume3.
Can anyone advise.....?
Thanks in advance..
Chris
    system1 (system2)
    q9650 3ghz (i7 920)
    Asus p5q deluxe (p6t deluxe)
    16gb ddr2 (12gb ddr3)
    Nvidia 8800GTS 640mb (285gtx 1gb)
    on board
    Eizo CG301w, Dell 2407
    2560 x 1600 + 1920 x1200
    Raptor 74gb,
    Raptor 150gb,
    500gb x2,
    320gb,
    750gb
    (raptor 150gb, 2x 500gb)
    ocz 600w (ocz750w)
    coolermaster stacker (coolermaster 690)
    many fans
    intellimouse
    apple slim aluminum jobbie
    2mb
    Wacom A3 tablet, Epson 3800
Brink
Staff member
mvp
Hello Chris,
To ID the drive, you can:
  • Open a elevated command prompt
  • In the command prompt, type diskpart and press Enter.
  • Type list volume and press Enter.
  • Make note of which drive is listed as volume 3. You should see the drive letter and size to help ID it.
  • Type exit and press Enter.
  • Close elevated command prompt.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
damocles
virtue & horse hair
Vista Pro
Cheers Shawn - that's useful.
Something really strange is happening.....I'm getting a series of service shutdowns and nearly every program I open comes up with a This program has stopped working box......Eventmanager is showing loads of NTFS and Service errors....
Could it be another bad RAM stick? - surely not again.
Chris
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    Raptor 74gb,
    Raptor 150gb,
    500gb x2,
    320gb,
    750gb
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
Brink
Staff member
mvp
Chris,
Were you able to run Chkdsk?
You might see if doing a System Restore use a restore point dated before these errors may help.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
lordbob75
Lord of Bobs
Vista Pro
Hey Chris.
Maybe a HDD finally dying? NTFS errors I would think would be from the HDD as that is the format system... Why would you think it would be a RAM error?
It seems to me more like a bad drive. Are all the programs that you are running all on the same drive?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
damocles
virtue & horse hair
Vista Pro
Hey Shawn and Lordbob...
I ran CHKDSK and it came up with errors on my c:drive. However symptom still persisted and I received a 0x0000003b.....
I ran memtest and indeed it came up with a hardware error....I've isolated the 'problem' ram , taken it out and the systems stable again....I guess the O/S was writing to the bad ram which made it throw a wobbly....Can not rule out a failing drive, although I put my win7 hard drive(different drive) and it came up with similar error in the event viewer but was more stable when it came to shutting down programs.....
I am going to RMA the stick - It's business as usual now.
Thanks guys.
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    Raptor 74gb,
    Raptor 150gb,
    500gb x2,
    320gb,
    750gb
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
Dwarf
The Contemplator
Hardware problems with RAM memory can manifest themselves in numerous ways, depending on whereabouts the problem is. If the problem is in that section of memory where system drivers are loaded, then you can get a whole series of problems, ranging from failure to boot, random BSODs, audio and graphic distortion. Sometimes, this is an intermittent problem where one or more bits swap states for no reason. The memtest program (and I recommend the bootable version) is able to check for these. Either way, if errors are being picked up, there is absolutely no way to repair RAM. It must be replaced.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Brink
Staff member
mvp
Thanks guys.
Chris,
I'm happy to hear that you got it sorted out. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
