quietstorm
There isn't only one cd that will do everything.
When you boot Gparted , what does it show?
Does it see partitions? What does it say they are?
If Gparted doesn't see the drive - at the very least, it should show one large Unallocated drive, even if the partition table is a mess - then there is almost certainly a physical hardware problem.
If that is the case, you need to get someone to repair it. If the HD itself has failed - you will have a lot of trouble/expense getting data off it.
When it first boots..there is about 6 options you have to choose
Next..it starts coding..massive words, commands, etc
Next...It brings up a screen like a Windows Desktop
Then..from there..it shows nothing for a partition or a drive!!
Like I said over and over..I do not what I am doing..hell it might be the options
I use might be a reason why it does not show a drive, partition, etc.
- HP
