Solved Having trouble with keeping protected mode on
patch41
Vista Pro
Hi Folks, i am having trouble keeping protected mode on in Internet explorer, I get the pop up saying turn on protected mode, I go into tools tick the box to turn it on, I apply, ok, then few minutes later the pop up tells me to turn it on as it is off again, any suggestions as to whats turning it off, or how i can keep it on, Thanks
patch41
Vista Pro
Thanks for your reply Allen D, Sorry did not get back to you sooner, been having a lot of trouble with the pc, Yes I did try tools, internet options, advanced tab and reset everything to default, didn't help, I think my trouble started when I installed chrome, and I didn't untick the box which automatically installed MacAfee, I have Norton which comes free with my Comcast subscription, I do backup my
PC every couple of weeks, so I did a system recovery which I was trying to avoid, but I do thank you for trying to help
Allan D
Hello Patch41,
Was the issue fixed by performing the system recovery?
Please write back to the forum if you need any further assistance.
patch41
Vista Pro
Thanks Allen D, yes everything is running smooth now, I think it started when I accidentally installed MacAfee, that's when it seemed the problem started.
