Katokato
Banned
In one of my previous posts i was asking around to see if i can use the HDradeon 5750 XFX: http://www.newegg.com/Product/Prod [...] 5750%20xfx
My friend told me that the 5750 would be a bit weak so he suggested that i should get the 5770 instead: http://www.newegg.com/Product/Prod [...] -_-Product
Ive seen that the 5770 card is one inch longer than that 5750 (which was told to me that it would fit).
But since the 5770 is one inch longer do you guys think that it will still fit inside this ? (scroll down half way that page and you will see a diagram of my mobo): http://h10025.www1.hp.com/ewfrf/wc [...] ct=3436818
Please give me your thoughts on this guys!!11!1
Thanks
-Kelvin
Thanks
-Kelvin
- Hp pavillion a6110n
- amd athlon 64 x2 live! 4400+
- 4 gigs 3.3 useable
- Graphics Card(s)
- Finally! SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 12
- generic pnp monitor
- 1280x1024
- 7.2k rpm
1 linux ubuntu partition
1 vista partition
1recovery partition
1 windows 7 partition
1linux swap partition
- PSU
- 500W, antc earthwatts EA500
- Case
- normal black case
- Cooling
- fans
- saitek cyborg gaming keyboard
- logitech mouse (small to fit hand perfectly)
- dsl
- Other Info
- 2.3 ghz amd
