JethroBodine08
Hello everyone,
I have a problem with my HDMI output. I have a Dell Inspiron 1525, running Vista Home Premium 32bit. I recently discovered that I can hook my laptop to my 60in LG Plasma display via HDMI and do homework large and in charge. Unfortunately, it has stopped working.
Everything worked fine for a few days, I just plugged my cable into the back of the tv, clicked "Connect to Display" in my "Personalize" window from the desktop right-click drop-down menu and everything worked perfectly. I have not adjusted the refresh rate or resolution or any other setting for that matter.
When I came home from school today I repeated all the same steps but now when I plug the cable into the computer, the sound (when you plug into a port aka. dooDEE, I know, I'm nuts, just say it to yourself) keeps going back and forth between plugged in and unplugged (DEEdoo). Repeatedly over and over as if I would keep plugging it in and unplugging it again. (As if there is a problem with a driver)
I have searched all through the device manager for !'s and disabled the HDMI Audio Output Codec then re-enabled, as well as reset my plasma display to default settings. The personalize panel also cycles through "Display Connected" and "No Display Detected" during this time.
Please, if you're a guru, extend some help, if you're gonna ask if the tv is plugged into the wall, don't waste our time. Any help from knowledgable sources will be much appreciated as I really do not want to pay Dell $60 to walk me through something that is probably very simple. I might add I recently acquired this computer from my mother, so obviously there is no prior restore point as she does not know what that is, I already tried that. Please PLEASE help me out as the big screen is much easier to do homework on. Thanks so much and God bless!
Thanks again,
Rick
Thanks again,
Rick
