Loner19881
Okay kinda new to computers but here it goes... I have Windows Vista Premium OS 32-bit. My motherboard is a BIOSTAR supports 32 or 64bit. Model mcp69 m2+ n68s+. I have a amd athlon dual core processor. Got ddr2 ram 240 pin 800 ram brand name Corsair... The OS I got came with my e-machine that I had and when installed on this comp that I built it keeps blue screening normaly when I play SC.. Here are the blue screen mini dump files that I decoded with WinDBG...
Probably caused by : ntkrpamp.exe ( nt!PpCheckInDriverDatabase+42 )
Followup: MachineOwner
Here is the information you asked for please help!
Code:
PAGE_FAULT_IN_NONPAGED_AREA(50)
Invalid system memory was refrenced. This cannot be protected by
try-except, it must be protected by a Probe. Typically the address is just
plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffff8e, memory referenced.
Arg2: 00000000, value 0 = red operation, 1 = write operation.
Arg3: 81f82029, If non-zero, the instruction address which referenced the bad
memory address.
Arg4: 00000000, (reserved)
Debugging Details:
READ_ADDRESS: ffffff8e
FAULTING_IP:
81f82029 8b5510 mov edx,dword ptr [ebp+10h]
MM_INTERNAL_CODE: 0
DEFAULT-BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS-NAME: System
CURRENT_IRQL: 0
TRAP_FRAME: 84f713f0 -- (.trap 0xffffffff84f713f00
ErrCode = 00000000
eax=00000001 ebx=00000000 ecx=81f49400 edx=00000000 esi=81f4980
edi=00000000
eip=81f82029 esp=84f71464 ebp=84f71488 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00210246
nt!PpCheckInDriverDatabase+0x42:
81f82029 8b5510 mov edx,dword ptr [ebp=10h]
ss:0010:84f71498={HDAudBus!
Resetting default scope
LOCK_ADDRESS: 81f49600 -- (!locks 81f49600)
Resource @ nt!PiEngineLock (0x81f49600) Exclusively owned
Threads: 839ef020-01<*>
1 total locks, 1 locks currently held
PNP_TRIAGE:
Lock address :0x81f49600
Thread Count :1
Thread address:0x839ef020
Thread wait :0x2ba
LAST_CONTROL_TRANSFER: from 81e62dd4 to 81ead379
- amd athlon 7850 dual core
- Biostar
- 2 GB corsair 240pin 800 DDR2
- Onboard GC
- Onboard SC
- Dell
- 1024x768
- 240 GB HD
- Case
- E-machine case
- Cooling
- Vortex Cooler
- Microsoft
- Gateway 2000
- 12 Mb
