HELP - can't install or run any downloaded programs
bretth
3
please help!! whenever i download an .exe program or .msi installer vista shows:
iTunes installer for example, but occurs with all downloaded files. However programs i already had on my hdd install fine. I have not yet had time to test a 64 bit native app to see if it installs fine, but all the programs i try and fail to run once downloaded are on the compatibility list.
thanks
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
bretth
3
Thanks for your help but i can't extract the patch!!! unzip error
edit: i opened it on a different pc and added it to the registry, but the problem is still there. Any .exe, .msi, or any archive with an .exe or .msi in it does not run when downloaded. Errors range from 'Windows Installer Error 0x8007000d' to 'Unspecified Error 0x8004005' and others. I also tried uninstalling all updates, because i used to be able to run these files, but that did not help either.
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Flasse206
1
I had the same thing I could not install any downloaded programs. I have finally found the solution.
The problem is the wireless usb card. It somehow corrupts the data when installed in vista.
I have disconnected my wireless usb card and just plugged in a network cable and now everything works fine. I hope you have the same luck.
jam123
5
in vista with most of the software we may get this type of error. One possible error is registry corruption and second cause that it may possible that i tune version is not compatible with vista. I have faced same problem with 3d max. then i downloaded the patches for vista.
johngalt
Antidisestablishmentarian
3,922
Location
3rd Rock
IOW, now your seeing at least 3 different possible causes for this issue - so check all your software, not just the system files.
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
