Solved Help CI.dll Corrupt or missing!!!!!
Help CI.dll Corrupt or missing!!!!! i cant find any info anywhere.:(:cry:. It happened after i turned off my laptop using the power button because everything was frozen. now it says CI.dll is missing or corrupt. Is it even possible to fix. can you replace the one thats there. i've tried vista repair disk but it doesnt fix it.:mad:
any help is much needed.
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
Airbot
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
SIW2
Hi Fastboy 42,
Try downloading this -use it as a bootable cd, i.e. boot in from the cd you can make with it and it may root out any nasties.
Avira AntiVir Rescue System
Hope it helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
Thankyou very much guys:D. I was just about to reinstall windows. I'm just trying both right now. I have to run sfc/scannow off the windows repair disk. SIW2's idea look interesting to. I have to try them. Hope it works:sarc:
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Airbot
Good Luck
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
i dont now how to sfc /scannow from the vista repair disk:sarc:
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
SIW2
Hi fastboy,
1. Boot into the System Recovery Options screen.
2. Click on the Command option.
Then type in sfc /scannow then press enter, like this:
I do not have CI.dll on my system, I have ci.dll. That is why I suggested the download (you will need access to another pc , of course )
http://www.free-av.de/en/tools/12/avira_antivir_rescue_system.html
You place a cdr in the cd/dvd drive - do not format it, if Autoplay pops up, just close it.
Then rt click and run as admin on the .exe you downloaded
click Run , and Ok the uac prompt. Then click burn.
You now have a bootable cd to boot into your pc and find and hopefully remove any Trojans, etc.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
Airbot
#8
You can run it from the recovery menu/Command Prompt
Ahh, you beat me SIW2
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
#9
ci.dll is what i was supposed to say.:huh:
When i go into command prompt it doesn't have C:\windows\system32. instead it has X:\sources>
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
SIW2
Seems to be asking for a replacement file.
If someone posts you a copy of the ci.dll from a 32 bit system you can unzip it and copy to a cd.
Then go back to the command prompt , put that cd in and direct it to your dvd drive as the source.
I don't have 32bit - sorry.
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
#11
Thankyou SIW2.
So far in my scan, this is what i have detected, Trojan.wimad and JOKE/bluescreen.a (Which must be part of the screensaver I downloaded that simulates the BSOD).:huh:
Hi SIW2,
My laptop has got Vista Ultimate x86 SP1 and my Dad has got Vista Business x86 SP1.Can I copy ci.dll from Dads computer to mine or is the .dll different? :sarc:
OK i have ci.dll. how do i replace the old one?
instead of putting the file on a Cd can i put it on a Flash drive?
Could i have a little screen-shot tutorial please.:D (if its not a hassle)
Thank you:D So much SIW2:geek: and Airbot:geek: I really thought my laptop was stuffed.
(I wish i could give you some more rep,but i have to spread some reputation around first.)
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
SIW2
Hi fastboy,
Try this:
3. Put the cd onto which you have copied the ci.dll file in the drive
4. Assuming your optical drive is E ( if not, use whatever letter it is ) at the command prompt, type
copy E:\ci.dll C:\Windows\System32
then press enter
If prompted to overwite the existing file, type y and press enter.
Assuming it tells you it was successful, remove the cd and restart.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
#13
Thankyou so much i will try in a minute. its just that im running the antivirus scan which has taken 6 hours so far:D
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
SIW2
That's a long time - what does it say it's doing ?
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
#15
do you know of a bootable command prompt , so i dont have to use repair disk. the repair disk is extremely slow.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
SIW2
As far as I know, that's the only way to get to command if you can't boot into the operating system.
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
Brink
Staff member
mvp
#17
Hello Fastboy,
Here's a copy of the C:\Windows\System32\ci.dll file for you from a 32-bit Vista Ultimate SP1 in the ZIP below.
I hope it helps,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
thanks;my machine is getting really slow ,there is no windows showing when i try to repair,all i get in the command prompt is "x sources:" too bad the genius at MS didnt consider a boot disk for Vista! would save a huge amount of trouble when their software bombs out.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
z3r010
Staff member
#19
Do a reinstall.....you know you want to :p
    Yes
    Operating System
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
SIW2
there should be a prompt after x sources , like this > that's where you type the copy command I posted earlier.
X:\sources>copy E:\ci.dll C:\Windows\System32
When you have copied the ci.dll to System 32 with any luck, you should be able to boot.
If not , then it is not just because ci.dll is missing or corrupt, the problem is deeper than that.
In that case I see no alternative other than reinstall - that's not so bad. If you have other issues, reinstall should sort them out as well.
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
