help deleting an xp partition
scottDB
3
Greetings,
Yesterday I opened something I shouldn't have, and hosed my XP partition. My computer's disk management information can be found below. I'm seeking to reinstall XP on the corrupted partition / delete the XP partition, repartition the drive again, and then reinstall XP. Could someone take a minute and outline the steps (and p'raps web resources so that I can use this as a learning experience) and programs which I'll need in order to achieve this? While I understand this process in theory, I'm here because the XP partition is the primary, and I'm quite afraid of doing irreperable damage in my bumblings...
Disk 0
D: <-- XP sp 2, comprimised
Healthy (System, Active, Primary Partition)
C: <-- Vista64, uncomprimised
Healthy (boot, Page File, Crash Dump, Log
Disk 1
E:
Healthy (Primary Partition)
I appreciate your time and responses. If I've posted in the wrong place, please put me in the right thread. Thanks.
Scott.
    Core2 Duo E6850
    2GB
    GeForce 8800 GT
Barman58
Staff member
1,797
Location
Newport, South Wales, UK
  • Show second system?
    No
    Operating System
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
scottDB
3
well, I think that's jumping the gun here... and that's awesome for the 2nd half of my issue (reinstalling xp correctly)...
but my comprimised partition is the primary & system ... how do I make it so my non-comprimised partition has these attributes?
    Core2 Duo E6850
    2GB
    GeForce 8800 GT
Barman58
Staff member
1,797
Location
Hi Scott,
are you able to boot into Vista?
If you are then the boot files are on the vista partition, ( this is normal as the default is to place the boot files on the start-up of the newest OS ), and it should be no problem to proceed with the re-install of XP as described in the step by step.
If not and you have the original Vista disk, use this to perform a start-up repair on the Vista install. when you have this completed, and vista is booting correctly you can can re-install XP.
Some more reading for you I'm afraid :) ...
Startup Repair - Vista Forums
If you do not have the original Vista disk to do the repair have a look at the options here ...
Create a Recovery Disc - Vista Forums
Hope this helps
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
scottDB
3
yup. Let me read through and work it out... hopefully I'll have great news in an hour or two...
    Core2 Duo E6850
    2GB
    GeForce 8800 GT
