Hello ahmad12 and Joan. I tried to search, could find nothing but these links :-
can help install your russian windows xp or Vista RU
Russian Computing Information (Penn State)
Finally a translated step by step. I don't read russian so I can't say if it is correct :-
Configure to boot to the CD-ROM, DVD- ROM
1. Insert a WinXP CD into your CD or DVD drive
2. Restart the system, when the Dell logo screen appears, press the CTRL+ALT+F8 key several times to enter the Boot Menu. * If you wait too long and the operating system begins to load into memory, let the system complete the load operation. Then restart the computer and try again.
3. Select Option for “ATAPI” CD-ROM or “IDE”CD-ROM and press Enter
4. The system will restart in 2 seconds time.
Begin the Windows XP Setup Process
1. The following message appears for 5 seconds on left top corner: Press any key to boot from the CD.
2. Press the to boot to the Windows XP CD.
The Windows XP Setup screen appears.
3. Press the key to setup Windows.
The Windows XP Licensing Agreement screen appears.
1. Press the key to accept the license agreement.
If you have a copy of windows XP preinstalled earlier, setup will try to search for that copy and intend to prompt to Repair.
To Repair, press R
To continue install a fresh copy of windows XP without repairing, press Esc
C:\Windows ” Microsoft Windows XP Professional
In order to install a fresh copy of XP, press Esc
The partitioning screen appears.
If the hard drive is already partitioned (this is most common), press the key to continue.
If the hard drive partitions are not listed or detected, you will need to create a partition on the hard drive. Press the key and then follow the on-screen prompts to create a partition. If you are unsure which settings to select, you may want to use the default selections that are displayed.
1. If your hard drive already contains a copy of a Windows operating system, a Caution screen appears. Press the key to continue.
The format options screen appears.
You have several options to select from to format your hard drive:
Recommends that you select the first option, Format the partition using the NTFS file system.
1. Press the key to select the option that you want and then press the key.
The Caution screen appears if you select to format the hard drive.
2. Press the key to format the hard drive.
The setup program will now copy files to your system. This will take several minutes, please wait. After the files have been copied, a message appears and notifies you that the computer will be restarted.
3. Press the key to restart the computer or a timer will count down and restart the computer automatically.
When the computer restarts, the following message appears: Press any key to boot from the CD.
Note: Do not press any keys when this message appears and allow the operating system to load.
Формируйте к ботинку к CD-ROM, DVD - ROM
1. Вставить компакт-диск WinXP в ваш компакт-диск или двигатель DVD
2. Повторно начать систему, когда экран эмблемы Лощины появляется, нажмите ВЫСОКИЙ ЗВУК CTRL ключ F8 несколько раз, чтобы войти в Меню Ботинка. *, Если Вы ждете слишком долго и операционная система начинает загружать в память, позволять системе заканчивать операцию груза. Тогда повторно начните компьютер и попробуйте еще раз.
3. Выбрать Выбор для CD-ROM “ATAPI” или CD-ROM “IDE” и нажать ENTER
4. Система повторно начнется через 2 секунды.
Начните Windows Процесс Установки XP
1. Следующее сообщение появляется в течение 5 секунд на левом главном углу: Нажмите любой ключ к ботинку от компакт-диска.
2. Нажать к ботинку к Windows компакт-диск XP.
Windows экран Setup XP появляется.
3. Нажать ключ к Windows установки.
Windows экран Licensing Agreement XP появляется.
1. Нажать ключ, чтобы принять лицензионное соглашение.
Если Вы будете иметь копию окон XP предварительно установленной ранее, то установка будет пробовать искать ту копию и намереваться вызвать, чтобы Восстановить.
Восстанавливать, нажимать
родолжаться устанавливают новую копию окон XP без восстановления, нажимают Esc
C:\Windows ”Windows Microsoft Профессионал XP
Чтобы устанавливать новую копию XP, нажмите Esc
Экран разделения появляется.
Если накопитель на жестких дисках уже разделен (это является самым обычным), нажмите ключ, чтобы продолжить.
Если разделение накопителя на жестких дисках не будет перечислено или обнаружено, то Вы будете должны создать разделение на накопителе на жестких дисках. Нажмите ключ и затем следуйте, на-экране вызывает, чтобы создать разделение.Если Вы неуверены, какие параметры настройки выбирать, Вы можете хотеть использовать выборы по умолчанию, которые показаны.
1. Если ваш накопитель на жестких дисках уже содержит копию Windows операционная система, экран Caution появляется. Нажмите ключ, чтобы продолжить.
Экран вариантов формата появляется.
Вы имеете несколько вариантов выбрать из форматировать ваш накопитель на жестких дисках:
Рекомендует, чтобы Вы выбрали первый выбор, Форматировали разделение, используя систему файла NTFS.
1. Нажать ключ, чтобы выбрать выбор, что Вы хотите и затем нажимаете ключ.
Экран Caution появляется, выбираете ли Вы, чтобы форматировать накопитель на жестких дисках.
2. Нажать ключ, чтобы форматировать накопитель на жестких дисках.
Программа установки теперь скопирует файлы к вашей системе. Это займет несколько минут, пожалуйста ждите. После того, как файлы были скопированы, сообщение кажется и уведомляет Вас, что компьютер будет повторно начат.
3. Нажать люч, чтобы повторно начать компьютер или таймер будет считать в обратном порядке и повторно начинать компьютер автоматически.
Когда компьютер повторно начинается, следующее сообщение появляется: Нажмите любой ключ к ботинку из депозитного сертификата.
Нота: не нажимайте никаких ключей, когда это сообщение появляется и позволять операционной системе загружать.
