Solved HELP: HP Pavilion dv2000 Built-in Webcam Problem
Hello
Please help me with my HP Pavilion dv2000, i changed it from Win7 to Win Vista. then when i was installing the drivers from the HP website. everything was working fine and suddenly i notice that the webcam does not work. i got this error message from the Device Manager.
My Laptop is currently running at
Thanks in advance..
PS. i tried to install the driver like more than 10 times from yesterday and until now. still no good i tied to uninstall and reinstall, still no good.
EDIT 2 i also got this error message when i reinstall the driver.
    HP Pavilion dv2000
    AMD Turion 64 x2
    AMD
    1406MB
    Conexant HD
townsbg
~~тσωηsвg~~
Are the drivers specific to Vista 32 bit? I've found that some drivers are cross compatible between Vista and 7 but not all of them. Also if you had a 64-but version of 7 you cannot use 64-bit drivers. Also is this Vista disk from the same manufacturer? If not you can't use it.
As a side note 1.4 gb of ram is not sufficient for Vista. With that little you would have been better off with 7 since it handles memory slightly better. 2 gb is the absolute minimum with either OS though. Without at least 2 gb more than likely your system will be relying on virtual memory which is really slow.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
HHmmmm... i see.. so your saying that my laptop cant handle a 32bit driver?? soo i need to transfer my o.s. back to win 7,
ps. i think it was a 32bit win7 before i change it to win vista 32bit.
    HP Pavilion dv2000
    AMD Turion 64 x2
    AMD
    1406MB
    Conexant HD
townsbg
~~тσωηsвg~~
You will probably have to get a Vista driver however if you are using a Vista disk from another manufacturer then you will need to revert.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    Poweredge T140
    1440 x 900
    1 TB & 360 GB
Well i got it working after, putting it back to windows 7.. maybe the drivers does not match..
thanks for the tips..
    HP Pavilion dv2000
    AMD Turion 64 x2
    AMD
    1406MB
    Conexant HD
