I may have mouse troubles related to a found trojan(assuming it isn't a false positive).Here is the thread on the mouse problem so you folks can see what has been happening...
http://www.vistax64.com/general-dis...es-causing-minor-irritations-help-needed.html
What i need to know is if any relation to what you've read in the above thread and the trojan found or if it's a false positive and i should forget about it.The folder the alleged trojan was found in is the game Patrician 3 which i bought from gog.com over a month ago.The mouse problems began yesterday when i turned on the computer.Again,the problems are mere irritations.The computer is functioning normally.Just the odd behavior as described in the above linked thread.
- Cyberpower PC
- E8400 3.0Ghz
- Gigabyte GA-EP45T-UD3P Rev 1.0
- 8GB DDR3
- ATI RADEON HD 4870 1GB PCI-E
- Onboard HD 7.1
- 24" LG
- 1920x1200
- Hitachi 750GB SATA-II
- PSU
- Apevia Warlock Series 750W
- Case
- Apevia X-Telstar Jr. G Type/Black/Window
- Cooling
- 2 case fans + Coolermaster Hyper TX2 CPU Cooling
- Razer Copperhead
- Saitek Eclipse
- 12.0 Mbps
