Solved Help! "No Audio Output Device is installed"
Jkillaz98
My little brother was messing with my computer one day, when i came back in the room my computer was shut off. I tried to turn it back on but it wouldn't work so i restored it to factory setting, but now the sound doesn't work. When i scroll over the speaker icon on the taskbar it says "No Audio Output device is installed". I've tried nearly EVERYTHING.
I've Disabled and Enabled my sound drivers. I've tried updating my drivers. I've went to device manager and went to my driver and pressed "Scan for hardware changes". I've tried re-installing my drivers. And i downloaded that vista update that was supposedly made to fix this problem, And I've made sure that my speakers were plugged in. Someone give me suggestions on what i should do please? Thanks in advance!
wither 3
Is your sound manager a card or is it on the motherboard?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
That's what I was going to suggest, depending on your answer. Glad it's working.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
