Help Please.... What should i do?....
Lostazn
Hello, I am currently using my window 7 labtop to post this question? I had a virus on my window vista 32bit system. so i try using my factory recovery disc that i made and it goes will until i try to boot my computer back up and it say BOOTMGR is missing? I try everything and i in a mess right now.... Please if anyone know how to fix this error tell me. I REALLY NEED HELP...:cry::cry:
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hi again,
Forget to mention in my last post: If you don't have a recovery DVD or a reinstall disk with recovery capabilities, you can download the CD with recovery capabilities only here:
Windows Vista Recovery Disc Download — The NeoSmart Files
Do the download, burn the iso to a CD, and follow the instructions in my last post.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thanks... It works but another problem pop up. install window error... "the computer restarted unexpectedly or encountered an unexpected error" then the computer restart and same thing happen... I think the disc that i made when i bought the computer is mess up or something... any idea's?
I am slightly confused as to what went wrong. If you think it is the disk, try the link I sent you in my second post, however, can you give me a few more details?
Is this a black screen, offering you Normal Boot or Safe Mode, or is this a blue screen? If it is a Blue Screen of Death (BSOD), can you get into Safe Mode?
You ran Start up Repair, and it said success, but then this happened. This sounds like a standard failure to me. Try the Command Prompt solutions posted above. Does this help? Can you be as specific as possible?
Thanks very much,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I'm very sorry if i am confusing you... i found out that i didn't install the os correctly due to the corrupted Disc i made when i first bought the computer from retail store. At first it gave me the problem about my bootmgr. wasn't found and now it tell my i didn't install the OS correctly. the bad part is that i'm the 99.9% of the people who don't have the installation disc. i try to install the OS from the disc that the web provide but it didn't work because of install.wim wasn't found.
Thanks you very for your time to help.
Unfortunately, the disk from the web will not contain install.wim (all the Windows files compressed) all it does is provide the repair tools. If you would like, we can continue working to get your vista to reinstall.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
thanks... but i got window 7 H.P. already for $300. but can you tell me how to delete the bad sector in my hard drive... it's use to be 300(320GB) but now only show 48GB... i try reformat it but i still got the same result. I think the rest of the memory are use up on the old OS...
Thanks you again in advance....
To check your drive for bad sectors, and mark them as such:
Run ScanDisk on the drive in Windows , or run a chkdsk on the drive in Windows XP & 7
To reclaim sectors that are marked as "bad":
Find a utility such as WipeDrive that will write zeros to the entire hard disk, or use the standard windows format command
running "chkdsk x:" where x is your drive letter. The manual scan options are:
  • /F Fixes errors on the disk.
  • /V On FAT/FAT32: Displays the full path and name of every file on the disk. On NTFS: Displays cleanup messages if any.
  • /R Locates bad sectors and recovers readable information (implies /F).
"CHKDSK x: /F /R" would perform a full scan (including bad sectors) and attempt to fix them.
    Sony Vaio ns
    Intel Pentium Dual T3200 @2.00GHz
    Sony Vaio
    3.0GB Dual-Channel DDR2 @ 332Mhz
    Realtech High Def Audio
    Generic PnP Monitor
    1280 x 800 x 59 hertz
    250GB Toshiba MK2552GSX (IDE) Average Temp 29*C
    Synaptics pointing device STOCK
    lol standard plastic PS/2
    DL 6.76Mb/s - UL.37Mb/s
    Optiarc DVD RW AD-7560S CPU Average Temp 39*C
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
You're very welcome. Anytime,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
