Solved Help with disabling Windows Vista Auto Arrange
doctrout
:sa:
I HATE Windows Vista!!! This worthless piece of junk program takes it upon itself to periodically auto arrange my files on its own which is VERY annoying since I have several hundred documents sorted into numerous folders and I need to have them arranged in a particular manor so that I can find them when I want! However, I can usually fix the problem by doing a system restore but, after it auto arranged the files again this evening, I attempted to restore the system but, it told me that there are no restore points present on my computer!!! So, I tried downloading and installing the bat file for disabling auto arrange in Windows Vista 64 Bit listed in the tutorial per the instructions and I did see exactly what the tutorial said I would. But, I am STILL able to auto arrange the files by clicking on Auto Arrange! So, how do I PERMENENTLY disable this worthless feature?
    HP Pavillion
Brink
Staff member
mvp
Hello doctrout, and welcome to Vista Forums. :)
The tutorial below you mentioned will disabled auto arrange, but you are still able to turn it back on for any specific folder. I'm not sure what to say other than don't click on the "Auto Arrange" option that will turn it on for that folder. If you do, then clicking in it again will turn it off again for that folder.
http://www.vistax64.com/tutorials/294845-windows-explorer-auto-arrange-disable.html
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
doctrout
Hello y'all,
Thanks for the information. I was concerned that the .bat file had not worked when I discovered that I could sill auto arrange the files in a specific folder manually. However, as long at it quites auto arranging them on its own, I will be happy.
    HP Pavillion
Brink
Staff member
mvp
Anytime. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Ztruker
You might also want to look into a program like Iconoid or DesktopOK which remembers your Desktop icon positions and restores them at boot or any time you want.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
