Help with dual monitors
Ok i want 2 monitors on 1 desktop 1 is envision and the other one is acer i plug in the acer and it dose not detect the acer monitor is there any way i can get it recognizable ?
wither 3
I was looking at the Vista help files and it says to use the keyboard shortcut that turns on monitors to get to the New Display Detected dialogue box to set up the undetected display. I guess you'll have to figure out what that is. It say that FN + F5 combination typically works on mobile pcs. You might give that a try.
Are you plugging into a graphics card? Does anything at all happen when you plug in the monitor, e.g., does Windows tell you it doesn't recognize the device.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
right when i press the button to turn on the monitor i get no signal.
*edit* i tried it on another monitor and when i start it no signal ? do i need a diver to recognize it?
wither 3
Where specifically are you plugging in the monitor?
If you're plugging it into a graphics card, are you using the correct type of cable? For instance, if the monitor is VGA, you might need an adapter.
What is your graphics card?
Don't take this the wrong way- do you have the monitor power cord plugged in and the monitor turned on?
I'm asking all this stuff because, if all the connections are correct, when you plug it into your system, Windows should automatically detect it and provide the correct Windows driver. You can always install the driver for a specific monitor later.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
To be honist i really understood a little ok in the back of my computer there is a small blue cord that goes to the monitor to the desktop that is the second computer and the main computor cord a little bigger the the blue one and its grey
*EDIT* Yes it is a VGA what do you mean adapter i plugged it in
wither 3
I don't know what you mean by second computer. We're talking about one computer.
Can you tell me what the name and model number of your computer is?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Patonb
You need to activate the 2nd monitor in the monitor control properties
right click desktop, properties, display settings, then extend the monitor to the new one.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
wither 3
Do you mean Personalize\Display Settings? I had thought of that but when he installed the second monitor, I would have expected Windows to say it was installing the software for it but, he said nothing happened.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Patonb
No, monitors don't get installed, and unless told to use the monitor doesn't activate the monitor.
1 problem It docent recognize the computer and docent even detect it my computer is windows vista my 2 screens 1 is my main the other monitor is the acer AL1706 monitor
please help :confused:
wither 3
Did you try what Patonb asked?
If you disconnect the main monitor from the computer and plug the Acer into the same port, does it work?
What is the name and model number for your computer?
You never did tell me if you have a graphics card and, if so, what it is.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
there is one huge slot and one small slot the big slot the main monitor and the small the second monitor so i cannot put the second computer in the main slot and i have a 32 bit windows vista computer.
Patonb
Can you take a picture and upload it to somthing like photobucket.
wither 3
The size of the slots is what I was talking about in regards to the use of an adapter. It's the number of pins. The Acer uses 15 pin.
What I wanted to know is the name (HP, Dell, etc.) of your computer and the model number. Please provide it.
In addition, can you use the cable from the first monitor on your Acer to try to connect the Acer.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
wither 3
What is the model number of the HP?
Does the smaller connection on the computer where you're plugging in the ACER have 15 pins or holes?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
pearline59
I'm having same issue. I only have the blue monitor connecting on both monitor. I have adapter both plugged and the one in the blue on my PC. But, my Pc IS NOT DETECTING THE OTHER MONITOR.
    Windows 10
wither 3
In My Computer, it says you're running Win 10. Is that an error? If not, I suggest posting in tenforums.com.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
