Help with missing imapi drivers!
Hello,
This being my first post, I'm wondering how in the world my imapi drivers just disappeared? My tsst CD/DVD drive burned beautifully, but suddenly my drivers for my HP pavilion laptop are gone, how or why I'm not sure, but I need to know if I can get them back, short of a total reinstall? I've tried the Microsoft website, but all those imapi drivers say they are incompatible with my machine! HELP! oh, and thanks!
OK Rich,
So far I'm on my second run and nothing found, I will go a third and then follow your final instructions, if nothing, then I'll be back to post what my next options are(I dread a reinstall, lol)OK? Thanks again as I wouldn't have had a clue to do this, but hey give me a cell phone and I can do anything!
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Townsbg,
Checked for the imapi.sys as per instructions on the links you gave me and it is nowhere to be found, cannot find the imapi.exe under system32 either!
Well it isn't on my system and I didn't find it on device manager. Are you sure that you need it?
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
At least your out West, still early there. Over here its almost tomorrow. Good luck
His profile indicates that he has Vista 32-bit but you posted for 32-bit.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
