Help with random BSOD
Hello,
In the past 2ish months I've started getting random shut downs and restarts. When the machine comes back it attempts to Restore (which doesnt do anything) before it eventually starts back up. Sometimes it won't start up and will restart again however.
I've followed the directions and attached the BSOD Dump and System File collection App. I've also attached the Performance report.
Before I stumbled across this forum I did full hard disk analysis using Spinrite as well as Memtest and the Memory Diagnostics tool; all of which found no problems.
Here's some more info about my system:
Is Vista . . . - x86 (32-bit) or x64 ? 32 bit home premium - the original installed OS on the system? Original OS - an OEM or full retail version? OEM - What is the age of system (hardware)? 4ish years - What is the age of OS installation (have you re-installed the OS?) 4ish years
Thanks in advance.
-KC
EDIT: Added attachments.
    Dell a6357c
    3 gig
    Dell flatscreen
Thanks for the quick reply, sorry about the missing attachments :)
    Dell a6357c
    3 gig
    Dell flatscreen
Code:
 Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Windows_NT6_BSOD_jcgriff2.zip\Windows_NT6_BSOD_jcgriff2\Mini070511-04.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18327.x86fre.vistasp2_gdr.101014-0432
Machine Name:
Kernel base = 0x8224b000 PsLoadedModuleList = 0x82362c70
Debug session time: Tue Jul  5 05:42:37.161 2011 (GMT-4)
System Uptime: 0 days 0:22:22.832
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\system32\drivers\NIS\1206000.01D\SYMDS.SYS, Win32 error 0n2
*** WARNING: Unable to verify timestamp for SYMDS.SYS
*** ERROR: Module load completed but symbols could not be loaded for SYMDS.SYS
BugCheck 1000008E, {c0000005, 89e11f00, a76cd6f8, 0}
*** WARNING: Unable to verify timestamp for Ironx86.SYS
*** ERROR: Module load completed but symbols could not be loaded for Ironx86.SYS
Probably caused by : SYMDS.SYS ( SYMDS+6f00 )
Followup: MachineOwner
0: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 89e11f00, The address that the exception occurred at
Arg3: a76cd6f8, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
SYMDS+6f00
89e11f00 0fb6460e        movzx   eax,byte ptr [esi+0Eh]
TRAP_FRAME:  a76cd6f8 -- (.trap 0xffffffffa76cd6f8)
ErrCode = 00000000
eax=953e06e0 ebx=00000004 ecx=a76cd6e4 edx=00000000 esi=00000000 edi=00000000
eip=89e11f00 esp=a76cd76c ebp=a76cd794 iopl=0         nv up ei ng nz na po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010282
SYMDS+0x6f00:
89e11f00 0fb6460e        movzx   eax,byte ptr [esi+0Eh]     ds:0023:0000000e=??
Resetting default scope
CUSTOMER_CRASH_COUNT:  4
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0x8E
PROCESS_NAME:  ccsvchst.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 89e132bb to 89e11f00
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
a76cd794 89e132bb 953e06e0 a76cd818 00000400 SYMDS+0x6f00
a76cd7b8 89e1a27e 00000000 00000000 b7d85cf0 SYMDS+0x82bb
a76cd804 89e1a42a a76cd818 00000000 a6b56010 SYMDS+0xf27e
a76cd84c 89e3b047 8ea1ae40 b480d9f0 a6b56010 SYMDS+0xf42a
a76cd88c 89e229d4 00000008 a6b56010 00000000 SYMDS+0x30047
a76cd9c8 89e1d874 a6b5fe70 00000000 00000000 SYMDS+0x179d4
a76cd9e0 89e1da23 89e4f428 89e50020 8cd74630 SYMDS+0x12874
a76cdb14 89e54587 a6b5fe70 00000000 a6b56eb0 SYMDS+0x12a23
a76cdb34 94cd12a2 a6b5fe70 00000000 00000065 SYMDS+0x49587
a76cdbe8 94ccaa18 a76cdbfc 898e98b8 00000000 Ironx86+0x122a2
a76cdc08 94ccc777 00000114 8880e738 a76cdc2c Ironx86+0xba18
a76cdc18 94ccc815 898e98b8 8984df50 8880e738 Ironx86+0xd777
a76cdc2c 8228f976 8880e738 898e98b8 898e98b8 Ironx86+0xd815
a76cdc44 82491c33 8984df50 898e98b8 898e9928 nt!IofCallDriver+0x63
a76cdc64 824923d8 8880e738 8984df50 00000000 nt!IopSynchronousServiceTail+0x1d9
a76cdd00 824934a2 8880e738 898e98b8 00000000 nt!IopXxxControlFile+0x6b7
a76cdd34 82295c7a 000023e8 00000000 00000000 nt!NtDeviceIoControlFile+0x2a
a76cdd34 772a5ca4 000023e8 00000000 00000000 nt!KiFastCallEntry+0x12a
02b6f650 00000000 00000000 00000000 00000000 0x772a5ca4
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMDS+6f00
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  SYMDS+6f00
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: SYMDS
IMAGE_NAME:  SYMDS.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4cfece54
FAILURE_BUCKET_ID:  0x8E_SYMDS+6f00
0: kd> Lmtsmn
start    end        module name
90fdc000 90fe9080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
80607000 8064d000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
91794000 9179c000   Afc      Afc.sys      Wed Feb 23 01:58:55 2005 (421C29AF)
94c02000 94c4a000   afd      afd.sys      Thu Apr 21 09:58:25 2011 (4DB03801)
8a323000 8a333000   amdk8    amdk8.sys    Sat Jan 19 00:27:20 2008 (47918A38)
950f7000 95100000   ArcSoftKsUFilter ArcSoftKsUFilter.sys Thu Mar 27 03:13:42 2008 (47EB4926)
950cd000 950d0e40   ASPI32   ASPI32.SYS   Fri Sep 10 19:46:10 1999 (37D99842)
80712000 8071a000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
8071a000 80738000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
917e1000 917e4000   BdaSup   BdaSup.SYS   Sat Jan 19 00:53:30 2008 (4791905A)
927ec000 927f3000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
95003000 950cd000   BHDrvx86 BHDrvx86.sys Thu May 12 16:20:44 2011 (4DCC411C)
8041a000 80422000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
a337e000 a3397000   bowser   bowser.sys   Tue Feb 22 08:23:54 2011 (4D63B8EA)
9ecb0000 9ecbe000   cdd      cdd.dll      unavailable (00000000)
acd90000 acda6000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
9179c000 917b4000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
80463000 80543000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
92728000 92736000   circlass circlass.sys Sat Jan 19 00:53:24 2008 (47919054)
8a5a3000 8a5c4000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80422000 80463000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
9518d000 9519a000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a5c4000 8a5cd000   crcdisk  crcdisk.sys  Thu Nov 02 04:52:27 2006 (4549B1CB)
805cc000 805e3000   dfsc     dfsc.sys     Thu Apr 14 10:59:03 2011 (4DA70BB7)
8a592000 8a5a3000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
95117000 9513c000   Dot4     Dot4.sys     Sat Jan 19 00:49:12 2008 (47918F58)
95151000 9515a000   Dot4Prt  Dot4Prt.sys  Sat Jan 19 00:49:09 2008 (47918F55)
9510a000 95117000   dot4usb  dot4usb.sys  Sat Jan 19 00:49:09 2008 (47918F55)
927c0000 927e5000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
9519a000 951a4000   dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
951a4000 951c1000   dump_nvstor32 dump_nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
951c1000 951cb000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
92f23000 92fc3000   dxgkrnl  dxgkrnl.sys  Thu Jan 20 08:50:57 2011 (4D383DC1)
8a56b000 8a592000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
94d91000 94def000   eeCtrl   eeCtrl.sys   Tue May 03 00:23:33 2011 (4DBF8345)
807d8000 807f6000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Tue May 03 00:23:34 2011 (4DBF8346)
807c8000 807d8000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
80796000 807c8000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
945f3000 945fc000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:27:57 2008 (47918A5D)
8a2eb000 8a306000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
917b4000 917b9280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
82218000 8224b000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
9160b000 91698000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
951ec000 951fc000   HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
951e1000 951ec000   hidir    hidir.sys    Sat Jan 19 00:53:18 2008 (4791904E)
91fcc000 91fd2380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
90f0a000 90fbf000   HSX_CNXT HSX_CNXT.sys Thu May 08 16:04:13 2008 (48235CBD)
90e08000 90f0a000   HSX_DP   HSX_DP.sys   Thu May 08 16:03:14 2008 (48235C82)
8a3a8000 8a3f4000   HSXHWBS2 HSXHWBS2.sys Thu May 08 16:05:16 2008 (48235CFC)
a32f4000 a3361000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
8a333000 8a346000   i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
94d34000 94d91000   IDSvix86 IDSvix86.sys Tue May 31 19:39:26 2011 (4DE57C2E)
94cbf000 94ce3000   Ironx86  Ironx86.SYS  Fri Nov 12 18:05:54 2010 (4CDDC852)
8a346000 8a351000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
94def000 94df8000   kbdhid   kbdhid.sys   Sat Apr 11 00:38:40 2009 (49E01ED0)
80402000 80409000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8a171000 8a19b000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
89f27000 89f98000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
a32be000 a32ce000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
8a306000 8a321000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
a40cc000 a40cf180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:26:59 2006 (449716A3)
90fbf000 90fcc000   modem    modem.sys    Sat Jan 19 00:57:16 2008 (4791913C)
8a5cd000 8a5dc000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
8a400000 8a40b000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
94df8000 94e00000   mouhid   mouhid.sys   Sat Jan 19 00:49:16 2008 (47918F5C)
80702000 80712000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
a3397000 a33ac000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
a33ac000 a33cd000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
a33cd000 a33ec000   mrxsmb   mrxsmb.sys   Fri Apr 29 09:24:39 2011 (4DBABC17)
a4004000 a403d000   mrxsmb10 mrxsmb10.sys Fri Apr 29 09:24:48 2011 (4DBABC20)
a403d000 a4055000   mrxsmb20 mrxsmb20.sys Fri Apr 29 09:24:41 2011 (4DBABC19)
917ec000 917f7000   Msfs     Msfs.SYS     Sat Jan 19 00:28:08 2008 (47918A68)
80656000 8065e000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
92677000 926a6000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
acd8e000 acd8f580   MSPQM    MSPQM.sys    Sat Jan 19 00:49:18 2008 (47918F5E)
8a10b000 8a136000   msrpc    msrpc.sys    Sat Apr 11 00:37:32 2009 (49E01E8C)
92736000 92740000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a55c000 8a56b000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
acd7a000 acd8d580   NAVENG   NAVENG.SYS   Thu May 12 16:37:22 2011 (4DCC4502)
acc03000 acd79e80   NAVEX15  NAVEX15.SYS  Thu May 12 16:35:45 2011 (4DCC44A1)
8a000000 8a10b000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
92fef000 92ffa000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
926bd000 926e0000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
92782000 92793000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
94c9e000 94cac000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
94c4a000 94c7c000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
8a136000 8a171000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
a32e1000 a32eb000   nglog    nglog.sys    Wed Sep 09 23:15:35 2009 (4AA86F57)
92fcf000 92fe4000   ngvpn    ngvpn.sys    Wed Sep 09 23:16:36 2009 (4AA86F94)
a32eb000 a32f4000   ngwfp    ngwfp.sys    Wed Sep 09 23:16:55 2009 (4AA86FA7)
90fea000 90ff8000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
94d2a000 94d34000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
8224b000 82605000   nt       ntkrpamp.exe Thu Oct 14 10:16:54 2010 (4CB710D6)
8a40b000 8a51b000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
927e5000 927ec000   Null     Null.SYS     Sat Jan 19 00:49:12 2008 (47918F58)
92804000 92f22960   nvlddmkm nvlddmkm.sys Thu May 22 18:51:06 2008 (4835F8DA)
91698000 91793180   nvmfdx32 nvmfdx32.sys Mon Sep 10 22:10:00 2007 (46E5F8F8)
80738000 80755000   nvstor32 nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
90fcc000 90fdb300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
94c7c000 94c92000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
80685000 80694000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
8065e000 80685000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
806ed000 806f4000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
806f4000 80702000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
a40d0000 a41ae000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
92793000 927c0000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
8a5f8000 8a5fca80   PS2      PS2.sys      Mon Dec 12 20:26:59 2005 (439E2363)
80409000 8041a000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
89f1d000 89f26200   PxHelp20 PxHelp20.sys Wed Mar 12 21:57:44 2008 (47D88A18)
917f7000 91800000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
926a6000 926bd000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
926e0000 926ef000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
926ef000 92703000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
92703000 92718000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
94cee000 94d2a000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
91ff4000 91ffc000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
917e4000 917ec000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
ace9f000 aced2000   RDPWD    RDPWD.SYS    Sat Apr 11 00:51:22 2009 (49E021CA)
a32ce000 a32e1000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
94400000 945f2940   RTKVHDA  RTKVHDA.sys  Tue Jan 15 06:18:36 2008 (478C968C)
a41ae000 a41b8000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8a1d7000 8a1eb000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
8a554000 8a55c000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
a320e000 a32be000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
ace0d000 ace93000   SRTSP    SRTSP.SYS    Tue Mar 29 22:43:18 2011 (4D9298C6)
94ce3000 94ced980   SRTSPX   SRTSPX.SYS   Tue Mar 29 22:43:23 2011 (4D9298CB)
a407d000 a40cc000   srv      srv.sys      Fri Feb 18 09:03:28 2011 (4D5E7C30)
a4055000 a407d000   srv2     srv2.sys     Fri Apr 29 09:25:09 2011 (4DBABC35)
a3361000 a337e000   srvnet   srvnet.sys   Fri Apr 29 09:25:08 2011 (4DBABC34)
80755000 80796000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
92ffa000 92ffb380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
89e0b000 89e62000   SYMDS    SYMDS.SYS    Tue Dec 07 19:16:20 2010 (4CFECE54)
89e62000 89f1d000   SYMEFA   SYMEFA.SYS   Sun Mar 13 23:20:09 2011 (4D7D8969)
8a1b1000 8a1d7000   SYMEVENT SYMEVENT.SYS Thu Mar 24 19:02:08 2011 (4D8BCD70)
94c92000 94c9e000   SymIMv   SymIMv.sys   Thu Mar 17 23:08:38 2011 (4D82CCB6)
89f98000 89ff1000   SYMTDIV  SYMTDIV.SYS  Thu Mar 17 23:08:22 2011 (4D82CCA6)
8a201000 8a2eb000   tcpip    tcpip.sys    Wed Jun 16 09:45:41 2010 (4C18D585)
a41b8000 a41c4000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
92fe4000 92fef000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
a41f3000 a41fe000   tdtcp    tdtcp.sys    Sat Jan 19 01:01:08 2008 (47919224)
8a19b000 8a1b1000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
92718000 92728000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
9ec90000 9ec99000   TSDDD    TSDDD.dll    Sat Jan 19 01:01:09 2008 (47919225)
ace93000 ace9f000   tssecsrv tssecsrv.sys Sat Jan 19 01:01:15 2008 (4791922B)
8a5ef000 8a5f8000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
8a5e4000 8a5ef000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
92740000 9274d000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
9517b000 9518ce00   usbaudio usbaudio.sys Sat Apr 11 00:42:54 2009 (49E01FCE)
950d1000 950e8000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
951cb000 951e1000   usbcir   usbcir.sys   Sat Jan 19 00:53:25 2008 (47919055)
950e8000 950e9700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
8a399000 8a3a8000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
9274d000 92782000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
8a351000 8a35b000   usbohci  usbohci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8a35b000 8a399000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
95100000 9510a000   usbprint usbprint.sys Sat Jan 19 01:14:40 2008 (47919550)
950ea000 950f7000   usbscan  usbscan.sys  Sat Jan 19 01:14:09 2008 (47919531)
9513c000 95151000   USBSTOR  USBSTOR.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
9515a000 9517ab80   usbvideo usbvideo.sys Sat Jan 19 00:53:38 2008 (47919062)
927f3000 927ff000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
91fd3000 91ff4000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
80694000 806a3000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
806a3000 806ed000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
8a51b000 8a554000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
94cac000 94cbf000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
92fc3000 92fcf000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80543000 805bf000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
805bf000 805cc000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
9ea70000 9ec74000   win32k   win32k.sys   Thu Mar 03 08:24:58 2011 (4D6F96AA)
8064d000 80656000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
a41e1000 a41f3000   WUDFPf   WUDFPf.sys   Sat Jan 19 00:52:49 2008 (47919031)
a41cc000 a41e0580   WUDFRd   WUDFRd.sys   Sat Jan 19 00:53:04 2008 (47919040)
a41c4000 a41cc000   xaudio   xaudio.sys   Thu Oct 18 18:36:53 2007 (4717E005)
917ba000 917e0500   xcbda    xcbda.sys    Fri Sep 07 14:36:07 2007 (46E19A17)
92604000 92677000   xcfe     xcfe.sys     Fri Sep 07 14:35:06 2007 (46E199DA)
91a06000 91f74000   xchal    xchal.sys    Fri Sep 07 14:33:46 2007 (46E1998A)
91f74000 91fcc000   xcmem    xcmem.sys    Fri Sep 07 14:32:37 2007 (46E19945)
Unloaded modules:
91600000 91608000   drmkaud.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
8a5cd000 8a5da000   crashdmp.sys
    Checksum:  00000000
8a5da000 8a5e4000   dump_storpor
    Checksum:  00000000
8a306000 8a323000   dump_nvstor3
    Checksum:  00000000
927f3000 927fc000   kbdhid.sys
    Checksum:  00000000
Welcome
You have given me quite a few Minidumps, I have checked only a few of the most current. Most of them come to different conclusions. A conclusion that was somewhat consistent is memory problems. Other conclusions were drivers, but different drivers were mentioned in each case.
I am of the belief that we may be talking about a memory problem here. Please, take this memory test, again. Run it for 8 passes, then take a good stick and test it in each slot for 8 passes. Memory is not my primary culprit, however which I think is Symantec.
http://www.geekstogo.com/forum/topic/246994-guide-to-using-memtest86/
At least for a test uninstall, your Symantec Protection and replace with Microsoft Security Essentials. There is a lot of circumstantial evidence that points toward Symantec, this is not an uncommon situation. Be sure to visit their website and use the uninstall tool.
A further review of your files leads me to believe that the primary culprit is Symantec, unintall that software and test. If there are no further BSODs, you are done. If BSODs continue the next step would be Memory test
At best, not helping the situation you are almost out of space on your hard drive. May I sugges that you either delete some software and other large items. You can transfer to an external hard drive.
Any changes that you made to the computer about the time of the BSODs, should be restored to the original condition
Make a full anti virus scan
Download and make a full scan with Malwarebytes.
Thanks, I'll look back into this tonight after work.
    Dell a6357c
    3 gig
    Dell flatscreen
Take your time. Ill be here when you are ready.
Well, I finished with the Memory Test last night and I tested all four sticks, one at a time and none showed any problems. I also uninstalled Norton and installed MSE. I haven't been at my machine much since then so I'll have to look and see if the problems been resolved by removing Norton.
FWIW, my hard disk space on my backup partition is getting full but I've got around 200 gig available on the main partition.
    Dell a6357c
    3 gig
    Dell flatscreen
I re-ran the memory tests again for about 10-14 passes for each of the 4 memory sticks. Once again, no problems were found. I've uninstalled some software but I'm not sure that's it either.
    Dell a6357c
    3 gig
    Dell flatscreen
I've uninstalled a lot of software, re-installed drivers and still not having any luck. Suggestions?
    Dell a6357c
    3 gig
    Dell flatscreen
OK, I ran the driver verifier. It took about a day and a half but it finally crashed. The driver identified was this:
dxgkrnl.sys
and the error message was:
Page_fault_in_nonpaged_area
    Dell a6357c
    3 gig
    Dell flatscreen
Upadate your graphics driver and lets see what happens
Well, I updated my graphics card via the Device Manager. It seemed to be working much better for about 2-3 days then the BSOD's started again. Now they are coming more frequently and I'm getting all kinds of different drivers identified.
ecache.sys
win32k.sys
just to name a few off the top of my head.
I think I'm going to try to just replace the RAM even though Memtest86 didnt find any problems.
    Dell a6357c
    3 gig
    Dell flatscreen
Well, things are starting to get really weird. All the sudden tonight I get a BSOD on bootup that says "the BIOS in this system is not fully ACPI compliant."
I was able to get it to boot up after that but ever since then, when I boot up I no longer see the HP splash screen and instead see the BIOS information on boot.
What would you suggest I do? I don't want to buy new memory if I'm having catastrophic failures. I'm not even sure I can finish backing up my files (before trying a reinstall of vista) without the system crashing on me during backup.
    Dell a6357c
    3 gig
    Dell flatscreen
