Help with syntax error in command prompt?
kiazand
Can someone fix this for me i dont really knw what this is saying when i put that command in. I wanted to do the command where it turns of the spikes while gaming and for some reason this is the error its showing. I think the statement C:\USERS\KOS>C:\Windows\System32\cmd.exe /k netsh wlan set autoconfig enabled=ye
s interface=Wireless Network Connection
juss needs some corrections juss dont knw what. Plz help thnx
Microsoft(R) Windows DOS
(C)Copyright Microsoft Corp 1990-2001.
One or more parameters for the command are not correct or missing.
Usage: set autoconfig [enabled=]yes|no [interface=]<string>
Parameters:
Tag Value
enabled - Set auto configuration logic to enabled or disabled.
interface - Name of the interface for which the setting has to be
changed.
Remarks:
Enable or disable the auto configuration logic on an interface. If it is,
disabled then Windows will not connect to any wireless network
automatically from the specified interface.
Both parameters are required.
Examples:
set autoconfig enabled=yes interface="Wireless Network Connection"
C:\Users\kos>
