High temperature alarm on HD
koldis1
Hi, I have a harddisk control program HDD Control2 (Guard) running on my laptop. Today at startup 9:30am I got the message: Temperature 19 °C Good - this hard drive is obviously cooled very well.
Now at 20:15 I got the message: Temperature 51°C Bad - You should think about cooling you hard drive better.
Further: Health 100%
Performance 100%
Sometimes, at heavy load,I think, I get even the treshold alarm of 52 °C together with a noisy audible signal and an even more severe warning message. Then I switch the pc to standby for a while.
The computer works good and fast always until now (hardware). Do I really have to undertake some protective measures? Internal cleaning of the computer and cpu-fan and/or getting some kind of so called laptop cooler stand. I wonder if this is really so critical, I have the computer since 2009 and the guard is installed only a couple of month and now I switched off the guard option, so I get no alarms any more.
performance benchmarks:
read perf. : 49,10 MB/sec
min: : 26,14 MB/sec
max : 67,95 MB/sec
accesstime: 32,89 ms
    Acer Aspire 6930G
    Intel Core2 Duo
    Makalu
    4 Gb
    Nvidia 9300M
    Laptop standard tft screen
americancritic
Hello cleaning your computer is important I live in Arizona and clean mine every 60 days by vacuming all the dust and dirt. I remove my fans and vacume under them and cleaning all around my fans etc. always a good practice, to much dust and dirt on you fans can lead to overheating...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
richc46
Overheating may be the most serious problem that your computer will face. If you follow the information in this aritcle the problems may be avoided.
Learn something – How to clean your laptop to solve overheating problems – The Blogs at HowStuffWorks
Try to download and use speccy to determine the tempertures that are inside your computer.
http://download.cnet.com/Speccy/3000-2094_4-75181811.html
You may also want to test your hard drive
http://pcsupport.about.com/od/toolsofthetrade/tp/tophddiag.htm
