Hoe to recover accidentally deleted preinstalled software
mikezells
I accidentally uninstall my dvd suite software. How can i recover this software without using cd or downloads. I believed the installer is somewhere in my hardisk or in the system but i dont know where to locate it.can u help me???
Use System Restore, to set it back to the date you brought it from, Go into Control Panel, System, system Protection tab (left hand side) and select "System Restore..."
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Labtec Media Desktop Y-SAD65
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
system restore is the only way to do it with out using the recovery cd.
unless you have recovery software that was installed with the pc.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS KEYBOARD
    MICROSOFT WIRELESS MOUSE
    CABLE 15MBPS
Try ShadowExplorer. You can look through your shadow copies(made when you make a restore point.) It works almost like an undelete program. Look through the shadow copies by date. If you find what you want, export it. It should work better than an undelete because the entire file set should be there if a shadow copy was made.
It's a freebie. In fact I think it's in the Free Software List for Vista, which is where I noticed it.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
