How are driver filenames derived from SGO?
10
How do I get from the ServiceGroupOrder outline to actual lists of driver filenames?
Below is the ServiceGroupOrder as it appears in the HKLM register. Below that is the ntbtlog from the same machine trying to load Vista normally (and failing). What file(s) is/are used to translate from "WdfLoadGroup" to "Wdf01000.sys" & "WdfLDR.SYS"
Code:
System Reserved
EMS
WdfLoadGroup
Boot Bus Extender
System Bus Extender
SCSI miniport
Port
Primary Disk
SCSI Class
SCSI CDROM Class
FSFilter Infrastructure
FSFilter System
FSFilter Bottom
FSFilter Copy Protection
FSFilter Security Enhancer
FSFilter Open File
FSFilter Physical Quota Management
FSFilter Virtualization
FSFilter Encryption
FSFilter Compression
FSFilter Imaging
FSFilter HSM
FSFilter Cluster File System
FSFilter System Recovery
FSFilter Quota Management
FSFilter Content Screener
FSFilter Continuous Backup
FSFilter Replication
FSFilter Anti-Virus
FSFilter Undelete
FSFilter Activity Monitor
FSFilter Top
Filter
Boot File System
Base
Pointer Port
Keyboard Port
Pointer Class
Keyboard Class
Video Init
Video
Video Save
File System
Streams Drivers
NDIS Wrapper
COM Infrastructure
Event Log
AudioGroup
ProfSvc_Group
UIGroup
MS_WindowsLocalValidation
PlugPlay
PNP_TDI
NDIS
TDI
iSCSI
Service Pack 2 3 16 2012 12:31:51.359
Loaded driver \SystemRoot\system32\ntkrnlpa.exe
Loaded driver \SystemRoot\system32\hal.dll
Loaded driver \SystemRoot\system32\kdcom.dll
Loaded driver \SystemRoot\system32\PSHED.dll
Loaded driver \SystemRoot\system32\BOOTVID.dll
Loaded driver \SystemRoot\system32\CLFS.SYS
Loaded driver \SystemRoot\system32\CI.dll
Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
Loaded driver \SystemRoot\system32\drivers\acpi.sys
Loaded driver \SystemRoot\system32\drivers\WMILIB.SYS
Loaded driver \SystemRoot\system32\drivers\msisadrv.sys
Loaded driver \SystemRoot\system32\drivers\pci.sys
Loaded driver \SystemRoot\System32\drivers\partmgr.sys
Loaded driver \SystemRoot\system32\DRIVERS\compbatt.sys
Loaded driver \SystemRoot\system32\DRIVERS\BATTC.SYS
Loaded driver \SystemRoot\system32\drivers\volmgr.sys
Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
Loaded driver \SystemRoot\system32\drivers\pciide.sys
Loaded driver \SystemRoot\system32\drivers\PCIIDEX.SYS
Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
Loaded driver \SystemRoot\system32\drivers\atapi.sys
Loaded driver \SystemRoot\system32\drivers\ataport.SYS
Loaded driver \SystemRoot\system32\drivers\msahci.sys
Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
Loaded driver \SystemRoot\system32\drivers\fileinfo.sys
Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
Loaded driver \SystemRoot\system32\drivers\ndis.sys
Loaded driver \SystemRoot\system32\drivers\msrpc.sys
Loaded driver \SystemRoot\system32\drivers\NETIO.SYS
Loaded driver \SystemRoot\System32\drivers\tcpip.sys
Loaded driver \SystemRoot\System32\drivers\fwpkclnt.sys
Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
Loaded driver \SystemRoot\system32\drivers\volsnap.sys
Loaded driver \SystemRoot\system32\DRIVERS\TVALZ_O.SYS
Loaded driver \SystemRoot\system32\DRIVERS\tos_sps32.sys
Loaded driver \SystemRoot\System32\Drivers\spldr.sys
Loaded driver \SystemRoot\System32\Drivers\mup.sys
Loaded driver \SystemRoot\System32\drivers\ecache.sys
Loaded driver \SystemRoot\system32\drivers\disk.sys
Loaded driver \SystemRoot\system32\drivers\CLASSPNP.SYS
Loaded driver \SystemRoot\system32\DRIVERS\AtiPcie.sys
Loaded driver \SystemRoot\system32\drivers\crcdisk.sys
Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys
Loaded driver \SystemRoot\system32\DRIVERS\tunmp.sys
Loaded driver \SystemRoot\system32\DRIVERS\FwLnk.sys
Loaded driver \SystemRoot\system32\DRIVERS\processr.sys
Loaded driver \SystemRoot\system32\DRIVERS\CmBatt.sys
Loaded driver \SystemRoot\System32\drivers\dxgkrnl.sys
Loaded driver \SystemRoot\system32\DRIVERS\atikmdag.sys
Loaded driver \SystemRoot\system32\DRIVERS\Rtlh86.sys
Loaded driver \SystemRoot\system32\DRIVERS\athr.sys
Loaded driver \SystemRoot\system32\DRIVERS\tdcmdpst.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\System32\Drivers\GEARAspiWDM.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbohci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\SynTP.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\msiscsi.sys
Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys
Loaded driver \SystemRoot\system32\DRIVERS\rassstp.sys
Loaded driver \SystemRoot\system32\DRIVERS\hamachi.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
Loaded driver \SystemRoot\system32\drivers\RTKVHDA.sys
Loaded driver \SystemRoot\system32\DRIVERS\AGRSM.sys
Loaded driver \SystemRoot\system32\drivers\modem.sys
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Loaded driver \SystemRoot\System32\Drivers\UVCFTR_S.SYS
Loaded driver \SystemRoot\System32\Drivers\usbvideo.sys
Loaded driver \SystemRoot\System32\drivers\vga.sys
Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Loaded driver \SystemRoot\System32\DRIVERS\rasacd.sys
Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys
Loaded driver \SystemRoot\system32\DRIVERS\smb.sys
Loaded driver \SystemRoot\system32\drivers\afd.sys
Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS
Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys
Loaded driver \SystemRoot\system32\DRIVERS\jswpslwf.sys
Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Did not load driver
Loaded driver \SystemRoot\System32\Drivers\dfsc.sys
    Toshiba
    AMD Turion
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Hello O negative and welcome to the forums :party:
With an sc query command, we can list all of the drivers, but it churns out a horrible output like this:
Code:
SERVICE_NAME: NisDrv
DISPLAY_NAME: Microsoft Network Inspection System
        TYPE               : 1  KERNEL_DRIVER
        STATE              : 4  RUNNING
                                (STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x0
C:\Windows\System32>
The first two lines are all that we want from this, so with a findstr command, we can get rid of the other information. This will then leave us with lots of these:
Code:
The first one is the driver without the .sys extension, so we'll have to write some code to add that to the end of each line. The second one is fine as it is :) But we'll need to output this to the text file after adding the .sys extension as we don't want it on this text.
So I've knocked together a little batch file to do all of that for you:
Code:
@echo off
sc query type= driver | findstr SERVICE_NAME > %SYSTEMDRIVE%\drivers.txt
set addtext=.sys
if exist %SYSTEMDRIVE%\tmpfile.txt del /q %SYSTEMDRIVE%\tmpfile.txt
for /f "delims=" %%l in (%SYSTEMDRIVE%\drivers.txt) Do (
      echo %%l%addtext% >> %SYSTEMDRIVE%\tmpfile.txt
del /q %SYSTEMDRIVE%\drivers.txt
ren %SYSTEMDRIVE%\tmpfile.txt drivers.txt
echo. >> %SYSTEMDRIVE%\drivers.txt
sc query type= driver | findstr DISPLAY_NAME >> %SYSTEMDRIVE%\drivers.txt
echo EOF >> %SYSTEMDRIVE%\drivers.txt
start notepad.exe %SYSTEMDRIVE%\drivers.txt
The only problem with this is that it will list it in the following format:
File A
File B
File C
Name A
Name B
Name C
But it's not too hard to convert between the two. If you want, I can make it output each to a different file, then you can view them side by side?
You might have to run it as an administrator.
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
10
sc query type= driver is a good way to get the type number, but it doesn't help me translate from the registry group name to the individual driver filenames. The example I gave, "WdfLoadGroup", happens to have at least two individual drivers associated with it. Somewhere, maybe in a .inf file--I don't know--the associations are listed.
    Toshiba
    AMD Turion
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Hello O negative,
Sorry about that, I misunderstood your first post.
You seem pretty well versed with Windows, I take it you know how to use command prompt? If not, then let me know and I'll explain it :)
If you do know, I would like you to run the following command for me please:
REG QUERY "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services" /s > %SYSTEMDRIVE%\CCSServices.txt
This will create a text file called CCSServices.txt in the root folder of your main drive (e.g. C:\CCSServices), can you attach this to your next post please? Hopefully this information will shed some light on the problem :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Thanks Tom!
This gives me the group names for the drivers and more. A gold mine of info.
see attached
Hello O negative,
You're welcome :) Is this all of the information that you wanted? Or do you want to have a hunt for where WdfLDR.SYS is found in your registry?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
10
I put together a spreadsheet with a column of all the service groups from ServiceGroupOrder and adjacent columns for drivers associated with those groups. Unfortunately, that query only provided driver/group associations for half of the groups. Some groups are quite large (SCSI miniport), but very few of the drivers are chosen. The sequencing is not straightforward either.
I'm still hoping to find some kind of script that is followed when the drivers are loaded, but I'm guessing it is more like a bunch of nested "if then else" instructions.
    Toshiba
    AMD Turion
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
#8
Sorry, I have absolutely no idea how to do that. Perhaps another member will enlighten us, but that sounds like a very complicated thing to do :(
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
3,375
#9
Hello!
I did not notice this thread before. Sorry for the delay. Maybe I can shed some light on how drivers are loaded. There is no specific script. Windows does not use scripts for this sort of thing, only kernel mode code. There is a HUGE amount more to say. I shall give you a very brief introduction, and you can ask questions.
There are two types of driver loading, explicit loading, and enumeration-based loading. Explicit loading is based on the contents of HKLM\SYSTEM\CurrentControlSet\Services, whereas enumeration-based loading is based on the results when the PnP manager dynamically loads drivers for the devices that a bus driver reports during bus enumeration.
For startup type 0 drivers, the operating system loader (winload.exe), called by the bootloader, loads the appropriate kernel and HAL images (Ntoskrnl.exe and Hal.dll by default), reads the VGA font file (vgaoem.fon by default), reads the National Language System files (l_intl.nls, c_1252.nls, and c_437.nls by default), reads the System registry hive (\Windows\System32\config\System by default), and then reads the boot time drivers (Start = 0 (SERVICE_BOOT_START)) out of the HKLM\SYSTEM\CurrentControlSet\Services, loads the file system driver, then loads the boot time drivers just scanned, and then prepares the CPU registers for the execution of Ntoskrnl.exe, and calls Nt!KiSystemStartup to perform the rest of system initialisation. This is all before the Windows Kernal has loaded :)
(n.b. This is for BIOS systems. For EFI systems, winload.exe is replaced by winload.efi)
The above was for Start = 0 (SERVICE_BOOT_START). When that equals 1 (SERVICE_SYSTEM_START), the I/O manager loads the driver after the executive subsystems have finished initialising.
As for what affects device driver loading order, many things!
The coursest control is through the use of Start = either 0 or 1 (SERVICE_BOOT_START or SERVICE_SYSTEM_START respectively). To refine its order, the HKLM\SYSTEM\CurrentControlSet\Control\ServiceGroupOrder\List key is used. For further refining, HKLM\SYSTEM\CurrentControlSet\Control\GroupOrderList defines tag precedence within a group. You can read more about this here: How To Control Device Driver Load Order
You can read more about the other available values of What Determines When a Driver Is Loaded
I am not going to go into the fine details of service/driver startup (which functions make which calls which do what), but if you want to know something specific, just ask.
I hope that this solves more confusion that it creates (I somehow doubt that!!), and do feel free to ask for help with any other aspects.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
3,375
#10
Now for the shorter answer :p
ServiceGroupOrder and driver names are simply enumerated from HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\{driver}
The startup order, and whether a driver starts up, etc. is based upon many other factors (from the registry keys given above).
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
