How can I enable the 'advanced settings' in Realtek HD audio manager.
libredy
I really need help enabling the 'advanced settings' for my audio manager.
I've aready reinstalled the drivers 'alot' of time using different versions of it.
See the attached screen shot of my HD audio manager.
The speaker and mic works fine, the problem I have is
when I plug in the headphone jack into my s/pdif slot
both the speaker and headphone plays sounds :confused:
I heard I can change this in the advanced settings...
which I can't acess...:cry:
Thanks in advance.
AllMac
Élite
Assuming you have on-board sound, it probably depends on the motherboard and what it can handle for sound and audio. I have the Device Advanced Settings option in the upper right corner.
Check this pic.
    Self Made System #1 2004
    Intel Pentium 4 650, 3566 MHz
    Asus P5LD2 Deluxe
    2048 MB (DDR2-533 DDR2 SDRAM)
    NVIDIA GeForce 8800 GTS (640 MB)
    Realtek ALC882/D/M @ Intel 82801GB ICH7 - High
    LG L204WT (Digital) [20" LCD]
    1680 x 1050
    [XP (160 GB, 7200 RPM, SATA-II) 8M]
    [Vista (320 GB, 7200 RPM, SATA-II) 16M]
    [Storage (500 GB, 7200 RPM, SATA-II) 32M]
    E-Power 570W Power Supply
    Antec SLK1650 Beige Mid Tower ATX Case
    Zalman CNPS9500 LED CPU Heatsink
    Microsoft HID-compliant mouse
    Logitech Standard 101/102-Key or Microsoft Natural
    Max 700 kbps Down / Max 90 kbps Up
    Coming Up --> Self Made System #2 MID2009
libredy
Well, I think my motherboard should be able to handle it. It worked fine on windows XP and even on windows vista, but ever since I installed sp1 it stopped working :(
Airbot
Well, like Allmac suggested, click on the Device advanced settings in top right corner and have it set to this.
Seperate all input jacks as independant input devices.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Airbot
This is the version I have. Thats' weird, mines says Realtek on the bottom left and your says ASUS:confused: lol
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
Killacore
Guru
Maybe you could try un-installing the driver, and getting the driver from the motherboard manufacturer's website instead of directly through realtek.
    Intel Core 2 Quad Q9550 @ 3.6Ghz
    EVGA 780i FTW SLI
    OCZ Platnium 8GB DDR2-1066 (5-4-4-18)
    2x eVGA 9800GX2 1GB DDR3
    Creative Fatal1ty X-Fi Titanium (PCI-E) & Sony MDR-V700DJ
    24" SOYO LCD
    1920x1200
    2x 150GB Western Digital VelciRaptors 10K RPM RAID 0
    2x 320GB Seagate Barracuda 7.2K RPM RAID 0
    ABS 900WATT Modular
    Antec P180B Gunmetal Sound Dampning
    Zalman 9700CNPS 110MM Fan, 4x120MM Case Fans
    Logitech G5 Gaming Mouse (USB)
    Saitek Cyborg Illuminted Keyboard (USB)
    15MB Down / 5MB Up (Cable)
libredy
I tried the manufacturer's website aready.
It was updated may 7the 2006, so I get a rthdcpl.exe compatability error with Vista
and no sounds :(
pooch
Old Dog
Hi Libredy,
Go to control panel, under Programs click on uninstall a program and uninstall the Realtek software after a restart Vista will automatically install the sound drivers again without the software.
Now when you right click on the speaker symbol in the notification area and left click on Playback devices This will open a window titled Sound by clicking on the Speaker and Headphone symbols and then the tab Levels you will be able to seperately adjust the sound levels
You should also be able to do this by right clicking on the speaker symbol in the notification area and left clicking on Open Volume Mixer
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
stormy13
Try the AC'97 driver,
Realtek
instead of the HD one. Reason for saying that is you have the ALC880 and according to the ReadMe for the HD driver the ALC880 is only supported by that driver under XP,
Driver Package R2.09
Realtek HD Audio Driver support all of Realtek HD Audio Codec in Vista/WinXP/Win2000/Win2003 .
1. Vista WHQL Supporting: ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VD, ALC660, ALC662, ALC663,
ALC260, ALC262,ALC267, ALC268, ALC269, ALC272, ALC273, ALC887
2. Windows 2000/XP WHQL Supporting: ALC880, ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VC,
ALC861VD, ALC660, ALC662, ALC663, ALC260, ALC262, ALC267,ALC268, ALC269, ALC272, ALC273, ALC887
That is from the previous driver set (R2.09) and not the latest, but I really don't see them changing the support from one driver to the next.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
libredy
Thanks for the reply.
but non of them works ...
Vista insn't able to install the audio drivers by iteself and the AC'97 driver
doens't install at all. Says something like not the right device or something . >_<;
pooch
Old Dog
When Vista restarted after the uninstall and it didnt load the drivers did you get any messages?
Does Vista notice that the hardware is there? Does it even try to install the drivers?
I am surprised that the drivers install with the software but that Vista will not automatically install the drivers on finding the driverless Hardware
Try with drivers uninstalled; Control Panel, Classic View, Add Hardware, follow the wizard, use the option to search for and install hardware automatically.
If this fails then the only answer left, is that although you can install the driver/software for Vista. That for what ever reason, (not supported/Hardware fault) the drivers do not and will not work properly. You will then just have to make the best of what you have.
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
libredy
When vista tries to install the driver I get a 'Devicedriver software was not successfully installed' message.
In device manager I yellow ! mark show on the 'High Definition Audio Device' and a 'This deivce cannot start(Code 10) error message in properties
stormy13
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
pooch
Old Dog
Yet the drivers with the software install ok, very strange!!
I think that you will end up going back to how it was and making the best of a bad situation. :(
With a bit of luck stormy's idea will work
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
stormy13
Not sure if it is included in Vista or not (and if not, if even offered through WU), but I remember seeing lots of people with similar problems with updated Realtek drivers not working or installing properly when Microsoft released the UAA HD driver.
Hopefully that will get libredy back up and running properly again.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
