A
Advice Pro
My PC won't boot neither normally or in safe mode and It won't repair itself, but I've found that if I press F8 after a restart, I can then select the option to repair and I getting System Recovery Options that ask for the user login. Either I don't have my user login info or it won't be accepted.
I have the Gateway disc that came with my PC. I also have discs created at Best Buy, 'Gateway Applications & Drivers' + 'Backup Discs'.
