how do I Change DEFAULT icons?
crash613
2
I have vista with ie7 and Maxthon installed. Once Maxthon was installed and set as the default browser all of the shortcuts to web pages that i have (i.e. favorites folder) and a few on my desktop all use the maxthon icon. I am able to manually change them back to the "e" icon by right clicking and changing icon. What i want to do is set it so that every NEW shortcut i create, as well as the old ones automatically use the "e" icon instead of the Maxthon one.
thanks
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
crash613
2
Thanks, that seems to be exactly what i need. I still, however, am having problems.. Maybe i am a little slow.
Here's what is going on.
Steps 1-4 go fine. In step 4 i look for the ".url" listing. This indicates that i need to change the "InternetIcon" setting..
Scroll down to that. go to the "DefaultIcon" folder. as per step 6
Per step 10: Change it to "C:\Program Files\Internet Explorer\iexplore.exe,-17"
Also tried various other ones in *.dll files (both 10A and 10b methods)..... none of the changes work.
close and re log on, and/or reboot.
No-joy, still using the same old Maxthon icons.
any idea what i am doing wrong?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You will most likely need to also change the icons for these file extensions as well: .htm, .html, .mht, .mhtml, and .url. Of course the Maxthon program could be resetting the icons back to it's anyway despite any changes you make to.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
swarfega
da Cleaner
Vista Pro
403
Location
Cambridge, UK
and .php which is quite common.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
