How do I do a system restore to an earlier date?
richmex
4
I started having a problem with my computer freezing up about 5 days ago, I did a scan, no problem, my memory is fine, only using about 60%. Then I went to do a system restore, but the problem is there is no restore dates in my system before, so I cant put it back to an earlier date, and the info that is showing does not say how to restore it from the day that I am trying to restore it, HELP!!!!!!!:sleepy: My computer is a compaq, 32 bit, 160 gig, 1.5 gig ram, and I am using Panda virus system
    compaq F700
    160 G
    1 GIG
lemur
1,533
Location
University of Kentucky
The information below is on how to do a system restore for Vista. If you do not have a restore date, you are not going to be able to restore to an earlier date.
How do I... Create and use System Restore in Windows Vista
You may want to check your event viewer to see if any errors are recorded.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
2,456
Location
NY USA
whydont you try to fix it first?
if you dinf out what is causing it you can probably fix it. have you ever had a true blue screen (the kind where the screen turns blue and it says stop folled by numbers?
If not you can go into event viewer (type event viewer in search) and go to the windows log?application tab. Is there errors there (lines with red signs on them)? if there are could you use the snipping tool (type snip in search) to take a screenshot of them and upload them to us?
If you need help with either let us know
Ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
JMH
Banned
2,141
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    SPECS.
    Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
    Drive 2. [ All as above.]
    CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
JMH
Banned
2,141
    1440 x 900
    SPECS.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
richmex
4
Hi zigzag3143, Here is the snipp shot of my event viewer, if you get a chance please let me know what you think. Thanks again
    compaq F700
    160 G
    1 GIG
2,456
Location
NY USA
#8
Thanks but no image. You need to use the attachment icon (shaped like a paperclip) in the reply to attach the image
Let us know if you need help
Ken
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
