You should upgrade or use an
alternative browser .
Solved how do I locate what printer drivers I have?
I want to find what current drivers my Canon MP600 all-in-one printer has and in Device Manager I can only find this scanner under Imaging devices
Hello Advice Pro,
You could open the Control Panel (classic view), click on the
Printer icon, then right click on your printer and click on Properties.
From here, look for a information or about type button or menu to see what the driver version is. This part is different per brand and version, so it may take a bit of digging around in the different menus and options to find it.
Cannon has the latest version as
1.11 from 11/24/2009.
Canon U.S.A. : Support & Drivers : PIXMA MP600
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
If the printer is USB connected, you could go to Device Manager\Universal Serial Bus Controllers and pick your printer. The driver would be listed under the Driver tab.
Just another way to access the information.
Operating System
Vista Home Premium 64 bit SP2
Cyberpower
Intel Quad CPU Q6700 2.67 GHZ
NVIDIA 780i
MSI GTX 560 TI Twin Frozr
Sound Blaster SB Audigy
Viewsonic VG2436
1920x1080p
Samsung HD 105SI
WDC WD20
Apevia XJupiter
air
Logitech MX 3200
Logitech MX 600
30 Mbps
