How do I reformat my laptop?
11
I'm having problems with explorer.exe on my laptop and I want to reformat my laptop to factory settings. How do I reformat my laptop? If it helps, I have a dell inspiron 6400.
Comments will be appreciated.
richc46
Staff member
20,105
Location
Fairfield County, CT
CrucialHoax
Action is Knowledge
1,033
If you have the CD's to re-install to factory settings that would be beneficial because you could boot-and-nuke it then put windows back a clean driver :)
If you do not have the CD's and you plan on using the back-up partition then just do a system restore and you'll be good to go.
Either way will work however, in either case please back-up your files...
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
11
Can I ask how you use the back up partition and system restore?
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
Hello WildStriker,
This link from Dell on how to do a factory restore and back up your files during it may help.
Dell - Technical Support
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
whs
2,026
Location
Germany/Florida
Here is the short version:
· Save all your important files.
· Unplug all the devices and drivers from your CPU (except the keyboard and the mouse), including your printer, camera and memory stick.
· Shut off the computer and then turn it on, or simply restart it.
· As soon as you see the Dell logo at the start keep on hitting the F8 key repeatedly. Do not stop until you see the screen that says "Repair your computer." There will be other options too but chose this option and hit Enter.
· Next you will see a prompt window giving you options to select the keyboard layout select from the drop-down menu "US" and click "OK."
· On the next screen you will be asked to select the user ID and the password of your Windows Vistaaccount. Select your user account, but make sure your user account has administrative functions. Type in your password. If you don't have a password, leave it blank and click "OK."
· Now you will come to a window with multiple options. Choose the one at the bottom that reads, "Dell Factory Image Restore." By clicking "Dell Factory Image Restore" , it will generate an operation that will take about 45 minutes to complete.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
