how do u tell if a file is corrupted or altered???
egorrs
36
I was contacted by a admin 4 a program after i said i had problems with there product and they told me 2 contact a tec. 2 fix my
corrupted or altered file.
But i dont have that kind of money.
so...
how can u tell if a file
and then how do u fix it?:geek:
rive0108
2,081
Location
Hampton Roads, Virginia, USA
  1. Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER: sfc /scannow
    The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
  3. Or try to recover using System Restore.
What is the exact nature of the progam's problem (error), and what's the software in question?
If its a 3rd party installed program that is not a part of Windows, there may be a compatabilty issue. try reinstalling the software, and/or use System Restore. File corruption may be a result of Registry cleaners or Malware, and may require O/S reinstallation depending on the severity of the corruption. Also try System Recovery to try and "undo" the changes. You can scan for and remove malware for free here.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
MilesAhead
Eclectician
2,442
so...
If the program files themselves are corrupted you can try uninstalling and reinstalling the program(depending on the Copy Protection/Licensing used if any of course.)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
egorrs
36
so...
ty but i dont no witch file is corrupted
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi egorrs,
What is the product/program in question?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
rive0108
2,081
Location
Reinstall Maplestory MMORPGs. That is how you fix a damaged/corrupted game software program.
Maplestory download
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
83
Location
Argentina
#9
If you remove an MMORPG and reinstall it, you SHOULD be able to use it proplerly.
If there's a problem with the updater it has, it should only be a temporary problem.
Also, even their own updaters can be the cause to file corruption on those games.
You should check their forums.
  • Other Info
    Windows 7 is love~~
rive0108
2,081
Location
#10
Maplestory download
uhh no
i herd that if u reinstall maplestory u wont be able 2 patch it
If you dont want to repair/reinstall then your choices are limited. You have not the knowledge or programming skills required regarding Maplestory files/folders to distinguish what is missing/corrupted, or causing registry issues, and therefore it is doubtful you will be able to fix it.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
egorrs
36
#11
how do u do that
sassofalco
What bad, bad,habit?
G'Day rive0108,
Does this apply in this situation [ #54 (permalink) and other posts refer ];
http://www.vistax64.com/overclocking-cooling/165144-vista-reliability-scores-6.html#post937412
......or is more information needed to ensure recovery of corrupted file? :shock:
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
rive0108
2,081
Location
#13
G'Day rive0108,
I think you may have to reinstall to fix your corruption, but the sfc scan may help
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
83
Location
Argentina
#14
how do u do that
How do you do what? Check their forums? You should know to whom you've registered. The game has many publishers, and each one has their own forum.
For all the rest, this is very common with MMORPGs, there's no need to scan the hole computer nor use system restore.
The most simple fix for that, is as told, reinstall and let it patch again.
Sometimes, just running the patcher (usually is just the launcher) downloads mismatched files. Although it depends on what method it uses.
  • Other Info
    Windows 7 is love~~
egorrs
36
#15
how do u do that
ok i re-installed it and i was right im no longger able 2 play maplestory!!!
ok now what do i do
rive0108
2,081
Location
#16
You understand there is a compatiblity issue with Maplestory and Vista, right? that is why you had a corrupted install.
The only way to get it to work is to run it under XP emulation
To properly Uninstall/Reinstall the program you need to open the nexon file, click Uninstall or Install.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
