how do you output sound through digital and front jack at same time
opiuz
Posts
8
i want to output sound through my digital output and through my front jacks at the same time, i.e while watching a movie through my digital output (monitor i.e video extended to my tv) and playing a game at the same time (game on my LCD), with sound coming out my front sound jack for the game. so basically in a nut shell, i want to watch movies and play games at the same time, while the respective sound comes through different outputs.
buffalo
Posts
11
I don't think you can currently do that with Vista (I certainly can't, anyway).
I find that I have to reconfigure my laptop every time I want to play a DVD through the HDMI port and then reconfigure it again when I've finished. I've seen many others posting about the same issue.
Clevo
Vista Fan
Posts
551
I suspect you will need two sound cards or split the output in some way but I would guess that motherboards will needs two separate circuits to output two distinct channels of sound to seperat outputs
johngalt
Antidisestablishmentarianist
3rd Rock
Posts
3,944
A lot of games will let you pick the sound if there is more than one installed....
Some Windows applicators will not - and thus using the combination, you'd set the one that the Windows app would use as default and set your game(s) to use the other....
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    Cable: 330+ Mbps down / 30+ Mbps up
    Windows 10 Insider Preview (current)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Lenovo
    Lenovo
    Lenovo
    Logitech MX Master | Synaptics TouchPad
    Lenovo
    330+ Mbps downstream | 30+ Mbps upstream
