How good are these specs?
Mr GRiM
Vista Supporter
I started off with those kind of specs and mine run fine, the only difference was that I had a Core 2 Duo 2.13Ghz, Nvidia 8600GT 512Mb Graphics Card, memory 2Gb @ 667mhz and a DVD burner. So I say Go For It!
As for memory its very cheap now and that's no obstacle unless you want to play games like Crysis and stuff like that.
mattinahat
m@thue
Power User
You do NOT need 4GB ram to run Ultimate but it helps if your into benchmarking, gaming, photo editing and video editing.
I ran Ultimate for 7 months on 2GB ram and all games worked fine however my problem stemmed from using Photoshop which pushed me to upgrade to 4GB.
The CPU is good but you might want to invest in a good heatsink and OC it just so you get more bang for your buck.
Hard drive is good and so is the screen. Because the CPU isn't overly expensive you could get a bigger screen but i dont know your budget.
You might know but my Ultimate uses about 25GB on my disc so is 92ish usable GB's enough for you? (92GB instead of 95GB's taking into account the 10 bits to a byte thing HDD makers use)
As for the heatsink i use a Tuniq Tower 120 and i can get my e6750 to go at 3.8GHz at just above stock voltage but im not sure you can still buy it...
Suggestions on a good heatsink anyone?
Read this article which talks about entry level CPUs, overclocking and cooling them
Hi Fmjc001, You could run Vista Ultimate quite happily on that system although as the guys mentioned a bit more memory would help.
Microsoft says for Home Premium / Business / Ultimate
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements
Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
You don't mention graphics, but with on-board there just isn't enough grunt for the Aero eye-candy. Also DirectX 10 is very hard on the GPU. You probably won't get any blistering speeds. Depends on your useage.
#8
Without knowing a little more about the card, and I'm guessing it's not your computer, all I could say is that the owner won't be playing Crysis anytime soon, but I'd be pretty certain there isn't much else they wouldn't be able to do. Those specs aren't real bad. Not everybody has a high end computor and a 2ghz Core 2 Duo is not a bad little processor. As for overclocking, you can, but there is a monetary and equipment cost. You have to weigh up if it is worth it. Unless the person is a high end gamer there is no real benefit for slight gain in performance you would get. For the cost of the cooling gear you could probably get a bigger processor. An extra gigabyte of memory would improve performance though and memory is pretty cheap/
PainlessTorture
Official Best Member
Vista Pro
#9
This laptop will not be playing any games at all. Its for work, it will be running MS Office 2007 possibly 2008 if its worth it. Have maybe a movie or two and thats it.
#10
No problems then. You might have to load your movies onto the hardrive to play them if thay are AVI. DVD's seem to work ok though in the Disk Drive. My daughter has a system with similar specs and apart from being slow to load and a bit sluggish compared to a higher end system it does all her work ok. She uses Office 2007 and Adobe Photoshop CS3 primarily. Adobe can put a strain on a system and although she has no trouble she can't open too many photo's at once. Best not to use all the pretty graphic stuff that's all.
smarteyeball
Eye know, eye know
You know Vista Ultimate isn't much different from Home Premium. It has Bit-Locker, which nobody I know of uses, and the Ultimate Extra's which are a waste of time and provide no value that I can see.
I'm sure somebody, somewhere uses Bit-Locker.... maybe.... The Ultimate edition was a bit of a waste, feature wise.
As for specs, I've got a dual core 2.8 (pre-core2 duo) , 7600GS and only 1.5 gig of ram and Ultimate runs very nicely with those specs. It's the extra 512meg that makes the difference ;)
mattinahat
m@thue
Power User
#13
If it is really only for movies, and MS Office then that computer is great.
My sisters laptop is a little under those specs and ran vista business fine (apart from that she has 512MB ram so it got too slow and she went back to XP).
With 2GB ram, and if you use it for what you have said, i doubt you will ever use more than 50% of it. That said don't take one stick out 2GB is much better than 1GB and i have found that even though vista doesn't use the extra 1GB very often it still makes it run better.
