how to completely remove zango
mathews2010
Banned
ahh...a couple of my friends came by and installed zango and as soon as they left i uninstalled it...but however...zango still exists in my firefox plugins and cannot get rid of it
as u can see i cannot disable or uninstall it...its a great nuisance
I have never heard of zango, but by the looks of your screen shot it's a firefox plugin.
just uninstall firefox, then if all of the plugin directorys haven't gone after the uninstall just delete em.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Dear mathews2010,
Zango is a user friendly program, and it is of paramount importance to us that our program will function properly and will be easily removed and installed.
To remove Zango from your computer, please do the following:
1. Close all open applications/programs/windows
2. Go to: 'Start' - 'Settings' - 'Control Panel' - 'Add\Remove Programs'
3. Click on 'Zango Browser and Wowpapers Tools'
4. Click 'Change/Remove' button
5. Check the components you wish to remove, click 'Next' and follow the on-screen instructions.
6. Restart your computer
Alternatively, you can use our uninstaller:
1. Click on the following link - http://installs.zango.com/downloads/Uninstaller/Uninstaller.exe
2. Click 'Run' and follow on-screen instructions
3. Restart your computer.
Zango support team can be easily contacted through our help site: http://catalog.zango.com/destination/corporate/supportform.aspx
or directly at: [email protected]
