Solved How To Copy DVD music to MP3 ??
germantechnology
germantechnology
I wish to copy some songs from DVD music concerts, to play on CD in car.
Is there any freeware around to do this ? I have DVD ripper, but am not clever enough to find individual tracks once copied to hard drive....any help would be appreciated. :confused:
    Acer 5920 Laptop
    Dual Channel DDR2 SDRAM Support 2GB of DDR2, 135 GB Storage
    Mobile Intel GM965 Express Chipset
    15.4" 1280 x 800
smarteyeball
Eye know, eye know
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
thepizzaman
Banned
i used audacity, all you have to do is download it get the lame mp3 encoder, and then run your speakers into your line-in and record and then save as mp3 and your done :D
Audacity: Free Audio Editor and Recorder
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
germantechnology
germantechnology
    Acer 5920 Laptop
    15.4" 1280 x 800
germantechnology
germantechnology
I can't personally vouch for this as I haven't used it to rip anything. There may be better alternatives - but it is free and supports the following formats:
*.vob , *.dat, *.mpeg, *.mpg
Free DVD MP3 Ripper - Freeware converts DVD to MP3, VCD to MP3, MPEG to MP3.
Just select your source file and set your output location and settings.
Thanks very much guys...will check it out tonight, and let you know,
GT.
Thanks for you help guys, have checked out both softwares, the problem I have is that I I don't seem to be able to get a specific track, when I rip files... ie a menu which gives me track 1 to 15 or a list of titles....... I have VOB files which is great but they do not give me any indication of track Numbers, plus there are only about six files, and songs overlap into those files, which means I can not copy a full song. Am I doing something wrong or is it that hard and I am chasing rainbows? I guess I need to find a program that will rip and display individual tracks. Is this possible...? Any advice appreciated.
    Acer 5920 Laptop
    15.4" 1280 x 800
germantechnology
germantechnology
GT.
I seem to have it all happening, thank you all for your help. The Free DVD MP3 ripper works well and works for me...thanks smarteyeball.
    Acer 5920 Laptop
    15.4" 1280 x 800
